7.3 IDI injectors
Old 09-23-2010, 08:46 PM
Rick Wallace's Avatar
Rick Wallace
Rick Wallace is offline
Originally Posted by ah1988
how do you post a new thread ive only learned how to reply
Go to the first page,look in the left upper and click where it says NEW THREAD Welcome to FTE!
Old 09-23-2010, 08:50 PM
ah1988's Avatar
ah1988
ah1988 is offline
thanks got it
Old 09-23-2010, 09:09 PM
mabc926's Avatar
mabc926
mabc926 is offline
Originally Posted by snaponprofile
If my truck blows blueish smoke, not just when started but all the time, could that be a indication I need new injectors??
They are stock and i'm at 104,000 miles.
What does the smoke smell like?
Old 09-23-2010, 10:22 PM
snaponprofile's Avatar
snaponprofile
snaponprofile is offline
I'm not sure, It doesn't smell great. I wasn't sure because most every diesel blows a puff of smoke when started, but my exhaust is blueish all the time.
Old 09-23-2010, 10:32 PM
mabc926's Avatar
mabc926
mabc926 is offline
I'm not sure what blue-ish smoke means, it could just be a leaky injector but I don't know.
I do know if the smoke smells sweet than it's a bad head gasket.
Old 09-23-2010, 11:09 PM
Festus Hagen's Avatar
Festus Hagen
Festus Hagen is offline
Methanoholic
Blue is oil
White is superheated (partially burnt) fuel OR coolant
Black is unburnt fuel
Blue smoke all the time indicates bad valve guides and or valve guide seals or piston rings.
And sweet smelling (coolant smell) smoke just indicates you have coolant being burnt, not where it comes from and is not limited to a head gasket.
-Enjoy
fh : )_~
Old 09-24-2010, 03:08 PM
snaponprofile
Should my exhaust have any color or should be clear all the time?
Old 09-24-2010, 04:49 PM
91 Super Duty's Avatar
91 Super Duty
91 Super Duty is offline
For my truck it depends at what point we are talking about; during startup when my glow plugs decide to come on I get very little or no smoke at all, when the glow plugs fail to come on I get a cloud of bluish grey smoke that smells like fuel. once that cloud goes away I usually do not get any really noticable smoke unless you stand at the very rear of the truck and watch the exhaust. For me that tells me along with what I would describe as a lifter noise if this was a gas job, that I have atleast one bad injector. My exhaust is more noticable at night when, i first start off and there are cars behind me.
For you it may be different, it all depends on color, smell, and if you hear any noises that do not sound normal to the engine. this is only my opinion based on what I have learned. the best suggestion I have is post a video, if you can of the smoke and maybe someone can help you diagnose it,
The lifter noise I am talking about is an obvious tick, tick, tick, tick, and does not sound like the clack, clack, clack, clack, they normally make. OK,OK every body can laugh at my description now.
Old 09-24-2010, 05:59 PM
fonefiddy's Avatar
fonefiddy
fonefiddy is offline
I bought a set from typefour.
The way I look at it is that any/every injector should be pop tested before installation. We all know that just because the package say's 'New'. It just means that You have about an 80% chance of it working as it was designed to.
Russ not only pop tests them, but pressure matches them to within 10 PSI or so. Makes for a much smoother running engine!
Old 09-24-2010, 11:34 PM
Festus Hagen
Methanoholic
Don't get me wrong, I'm not knocking what typefour does, I know nothing about him other then what I've heard on here and it has never been anything but praise!
Does he pull them apart to match them or just buy lots and test them all and match up!
-Enjoy
fh : )_~
Old 09-25-2010, 05:29 AM
fonefiddy's Avatar
fonefiddy
IF they need adjustment. He'll open them up, and shim them properly.
Old 09-25-2010, 10:27 AM
91 Super Duty
I left Type Four a message about the injectors, and we will see where we go from here. I can always get the standard set from Pensacola diesel.
  #28
Old 09-26-2010, 09:10 AM
typefour's Avatar
typefour
typefour is offline
-Enjoy
fh : )_~
I actually do it both ways, and they are within 100 lbs, the shims dont hardly come any closer.
Most of the time they come out at 50 to 75 lbs within. And it can be a time consuming pain but well worth it
  #29
Old 09-26-2010, 03:38 PM
Festus Hagen
Methanoholic
Thanks for the info Typefour ...
I understand the pain, been there doing that, only with shocks & springs, not Injectors.
Curiosity has me though, I understand you buy Delphi's, I am curious as to what you find on variances across them out of the box ???
-Enjoy
fh : )_~
  #30
Old 09-26-2010, 07:56 PM
whenry912's Avatar
whenry912
whenry912 is offline
I may be replacing my injectors soon, what does a pressure matched set go for?
Thanks!
Quick Reply: 7.3 IDI injectors
