Dually fender light replacement (on an '04) - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-22-2010, 09:01 AM
77f250sc 77f250sc is offline
77f250sc is starting off with a positive reputation.
Before I start,
Anyone have a link to instructions or pics on how to accomplish this?
I see that there is a clip on the back from the parts fisch. Do I need to remove the fender liner to get them out?
Trying to avoid the usual "Dang, shouldn't have done that!"
Thanks
'77
Old 09-23-2010, 12:00 PM
Best Method to Replace
Cut push pins and drop inner liner and replace - takes 15 minutes to do both.
I tried for 1 1/2 hours to try and remove and re-install on bulb to no avail.
Was not able to get inner steel plate to "lock" in place without removing inner liner.
After removal of light discover that I need the socket that holds the bulb and buld. Corrosion has eaten away the elements.
Anywhere on-line to get this part?
Dealer wants $15 for small plug and is a prepurchased part only. May call different dealer as well.
May do LEDs if nothing else.
Old 09-23-2010, 04:09 PM
aaronf350 aaronf350 is offline
aaronf350 is starting off with a positive reputation.
I got a replacement from Parts Guy Ed website. Look under "rear lamps->side marker lamps". There's the socket back part (that plugs into the wiring harness), a front part (either amber or red) and then if you need it, you can also get the metal retainer clip.
Turns out I didn't really need the clip after all... I thought mine was missing on my new-to-me truck, but it had just slipped back and was still there hanging on the wiring. Oh well, now I have a replacement just in case.
Installing was relatively easy for me since a bunch of the plastic clips had already come loose from the cover, so I could reach a hand back. Unfortuantely the loose cover meant water sprayed back onto the red one and now I discovered that it's socket is all corroded so I'll need to get a new one of those.
Picked up some replacement plastic clips at the local auto store and good to go. By the way, those new retainer clips can be really tight to squeeze on so you might want to fuss with it a bit ahead of time and see if you can do it first before using it to clip the socket assembly into the dually fender.
My progress so far.... reed1951 1948 - 1956 F1, F100 & Larger F-Series Trucks 111 09-22-2015 12:59 AM
Wheel housing splash shield IHateCommieCars 1999 to 2016 Super Duty 2 07-05-2015 09:57 AM
vacuum diagram needed for 6/77 F-250 4x4 351M Chris Popanz 1973 - 1979 F-100 & Larger F-Series Trucks 0 08-04-2014 02:08 AM
1977 F250 What?? SwampBilly 1973 - 1979 F-100 & Larger F-Series Trucks 56 12-26-2009 09:10 PM
1986 F150 Fuel Pump Relay Location 1970moose 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 09-15-2004 08:24 PM
Tags
2006, bulb, dually, f350, fender, ford, installlation, light, lights, marker, parts, retainer, side, socket, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
