Ball joints on dana 50
I've never done ball joints but I've done pretty much all the other front end. It isn't hard to take the hub assembly and hub off. Just be methodical and maybe even take pictures. But be prepared to do more than just the ball joints because you'll surely find something else once you get in. Ex: brake pads, turn rotors, u joints, bearings, races, seals, etc.
Received 3,657 Likes
on
depending on mileage and past maintenance you will most likely need spring bushings, shackle bushings and I beam pivot bushings, good time to put new grease seals in and re pack the wheel bearings, check u joints in front axle shafts.
don't waste your time or money on caster camber sleeves they will get changed when it is aligned. if they are the factory installed sleeves and all wear components are changed they normally are in spec just putting the original sleeves back in (they must be marked when you take them out) . all that is about a day's work if you have the tooling to do it
I've changed the pivot bushings already, and prob due for new tie rod ends ands steer links... just not sure how good the ball joints are, got a 160k of miles just figured it was time to do them..... and I have an axle seal that is leaking, it's the driverside one on the split diff....are those hard to do? will I have to pull the whole axle apart to pull out the shaft??
on
kyle j
10-15-2011 05:13 PM
Wagion
42
04-20-2011 03:45 AM
jsmith71
02-13-2005 09:12 PM
