54 on 56 f100 - Ford Truck Enthusiasts Forums
54 on 56 f100
Old 09-21-2010, 08:28 PM
cwest73's Avatar
cwest73 cwest73 is offline
cwest73 is starting off with a positive reputation.
54 on 56 f100
so i have a 56 f100 with tons of rust, but i found an add for a 54 f100 just the frame cab anf front fenders but i have to replace the fenders anyway, and the ad is only 500 dollars, so i was wondering if the cab and front clip from a 54 would fit a 56 truck????
Old 09-21-2010, 08:45 PM
sdetweil's Avatar
sdetweil sdetweil is online now
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
they will fit, but the 53-55 cabs are different shape then the 56.
the slant cab (windshield post slants back on the 53-55) and the vertical post cab on the 56..
so, you could do it, but then you wouldn't have a 56.. (generally more desired)
Sam
Old 09-22-2010, 12:26 AM
POS-F500's Avatar
POS-F500 POS-F500 is offline
POS-F500 is gaining momentum as a positive member of FTE.POS-F500 is gaining momentum as a positive member of FTE.
Where's the rust on your 56? May be able to use the 55 for patch panels.. depending on the areas.
Old 09-26-2010, 11:50 AM
cwest73's Avatar
well im getting a patch for the left rear cab corner which i know i cant use a 54 patch for it, but the floor pans are shot , so i might wanna use those, and the cab supports are shot, but the fenders are kinda bat just like they have rust in area that i would have to make my own curved patches and im not to good at that so i i just wanna use the fenders.
Old 09-26-2010, 01:20 PM
sdetweil's Avatar
rear cab corners are the same 53-56.. fronts are different 53-55, and 56.
floors I think are the same. fenders are the same.
Sam
Old 09-26-2010, 01:38 PM
CharlieLed's Avatar
CharlieLed CharlieLed is online now
CharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud ofCharlieLed has much to be proud of
There are a lot of variables...unless the 54 cab is ready to paint and install then you are probably better off fixing the 56 cab. If the 56 cab has a good roof...that is, no rotted drip rails...then the other repairs are usually worth the time and $$$ to make. Floors, cab corners, and rockers are pretty much standard replacements when it comes to cab repairs...if that's all you need then it would probably be better to use you $500 to buy replacement panels as opposed to a slant cab. I am not a big fan of using panels off another truck for repairs...too many aftermarket panels available that are in new condition and ready to install.
Here's a picture of my 56 cab when I was replacing the floors/rocker...if this looks too scary for you then maybe you should take another course of action.
Old 09-26-2010, 05:45 PM
sdetweil's Avatar
I think he said the cab brow skin was rusted thru.. typical of 56s..
Sam
Old 09-26-2010, 07:09 PM
CharlieLed's Avatar
You must be carrying on a private conversation with him Sam, I don't see any mention of rust in the roof in his posts.
BTW - I am going to be back your way on Friday, I am signed up for a workshop with Gene Winfield at Mercury Charlie's in Austin over the weekend. I've had a 50 Merc coupe on the backburner for a couple of years now and the wife is getting antsy to get it finished so I thought that I'd get a refresher course on Merc top chopping from the master! Charlie is having a little get together Saturday night at his shop; BBQ, live music, and about 100 hotrods...come on down if you have the time.
56 F-100 v2addict 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 11-23-2012 09:52 AM
56 f100 taylor90 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 03-09-2011 01:44 PM
56 fender interchange takid455 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 11-03-2009 11:02 PM
Will fenders and doors from a 56 F-600 fit a F-100 ? denisontexas 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-13-2003 06:44 PM
Converting '56 F600 Fenders to '56 F100 Fenders Bushwacker 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 07-14-2000 08:09 AM
Tags
53, 54, 5456, 55, 56, cab, chopping, corner, corners, f100, ford, forums, frame, installing, rear, rockers, slant
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
