Hey guys, long time no see. I miss all you guys dearly. Anyways, I am having fun with my project truck. I am to the point where I am pulling the engine. This is where I am stuck. I want to pull the turbo off so I can get to the rear transmission beelhousing bolts with ease. So how do I get the turbo off? Cause I sure as F#%& can't figure it out. Also if there is by chance a good thread on here with a bunch of pictures that takes you threw the process I would galdly appreciate it, cause I am lost on how I should do it (Going to pull the engine then the tranny.)
Never pulled an OBS turbo but...
Remove the bolts between the collector and the exhaust housing
Remove the 4 bolts between the pedestal and the block
Remove spider
Remove intake piping
Turbo should come out...
Now getting to the bolts is going to be the biggest challenge. The SD pedestal design is so much nicer...
You need a strong 1/4" swivel or a swivel socket for the rear one on the drivers side, extensions, adaptors, more swivels, etc... Have fun with that one.... the rest aren't bad
Can you get to it with something like a gear wrench?
I had my exaust manifolds off installing gaskets when i pulled my turbo and the up pipe seals were so bad they fell right out then you can reach in with a wrench going back together isnt bad with what 427 said when its clean and a little antisieze
lol this is going to suck I may just pull the engine then take the turbo off whens its on a engine stand. I need a CAT 6.6 and a 5spd lol XD I am still a little lost guys (No offense 427, but yeah) also mine so rusty I put PB blaster on it and I may try heating it with a torck tomorrow.
i had just pulled my engine, it will come out with the turbo. the bell housing bolts can be removed with just a ratchet. i have a 3ft extention with a swivel on it, makes bellhousing bolts a breeze. i also installed the engine with the tranny attached.
Good to know Pete. I don't care anymore as I eliminated the ebpv so its much easier now
I also don't plan on doing it again unless my money tree grows so I can upgrade someday down the road...
