Show me your fender flairs! - Page 2 - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-22-2010, 12:23 AM
9402fordguy's Avatar
9402fordguy 9402fordguy is offline
9402fordguy is starting off with a positive reputation.
Quote:
Originally Posted by Gastic3514 View Post
Lead off home run! I like them, they cover the area I want, and the price is right. Nice truck you have too! Thanks.
Thanks! and you're welcome....
I originally wanted to get the truck sprayed with the gold lower tone and throw some factory plastic flares on it, but I figured that would be a lot of $$$$ that I didn't have to spare so when I saw a truck with these on it I did some searching and found just how cheap they are to buy and the totally changed the look of the truck IMO
Old 09-22-2010, 12:39 AM
Gastic3514's Avatar
Gastic3514 Gastic3514 is offline
Gastic3514 is starting off with a positive reputation.
Thanks to all that posted. I like them all, but I have a "thing" for having huge flairs over smaller tires. My truck tires don't stick out that much. I ordered the stainless steel trim today. All of the trucks look good!
Old 09-22-2010, 08:01 AM
cubalz's Avatar
cubalz cubalz is offline
cubalz is starting off with a positive reputation.
Thanks for the compliments everyone! I really like how my truck turned out.
ChargersFaninCO - I paid around $450.00 on line for my fender flares. I thought they were expensive but I love the result.
Old 09-22-2010, 10:24 AM
JIA JIA is offline
JIA is starting off with a positive reputation.
It's flares, by the way.
Old 09-28-2010, 01:58 PM
reddogracing's Avatar
reddogracing reddogracing is offline
reddogracing is starting off with a positive reputation.
more pics
i would like to see some pics of the EGR and Bushwacker from the side. Looks to me like the EGR make the rear well opening longer, which I like. The bushwackers make it look taller and more of a square opening. I will be putting some kind of flare on mine soon.
Thank for all the pics guys, good looking rigs.
Old 09-30-2010, 02:54 AM
Boss_hoss's Avatar
Boss_hoss Boss_hoss is offline
Boss_hoss is starting off with a positive reputation.
Quote:
Originally Posted by 9402fordguy View Post
Not technically a 'flare' as they stay tight to the rig, but they do go up about an inch or so all the way around. Putco brand 'fender trim', got them online for a little over $100...
Fender Trim by Putco- 1999-07 Ford Ford F250/350/450/550 SD - POLISHED SS FENDER TRIM (4 Pieces): Ultimate Auto Accessories
Be careful with those. They trap dirt between the trim and the sheet metal so you need to take them off every now and then to make sure they are clean and not rusting away the metal behind them. Believe me I know from a bad expierence
Old 09-30-2010, 03:21 PM
ANy one
who has installed bush wacker cut outs,, question for ya.
Are the flexable enough to maybe not trim the top of the wheel opening?
I was thinking about just cutting the front and rear of the opening for the rear tires. Then use a heat gun if neccessary, fit the flares. i do not want the opening any taller, just more room front to rear.
Old 09-30-2010, 03:37 PM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
I don't think it would turn out very good. You would have to make them quite a bit wider to not stick down below the bottom of the box and they probably wouldn't keep their shape with the radius change.
Old 09-30-2010, 04:08 PM
cdrmotorsports's Avatar
cdrmotorsports cdrmotorsports is offline
cdrmotorsports has a good reputation on FTE.cdrmotorsports has a good reputation on FTE.cdrmotorsports has a good reputation on FTE.
JIA: What brand do you have? They look really good.
Old 10-04-2010, 03:09 PM
smotrs's Avatar
smotrs smotrs is offline
smotrs is gaining momentum as a positive member of FTE.smotrs is gaining momentum as a positive member of FTE.
Here's some of the Bushwacker OE style.
Old 02-05-2012, 12:47 PM
redbull660's Avatar
redbull660 redbull660 is offline
redbull660 is starting off with a positive reputation.
Quote:
Originally Posted by cubalz View Post
Here is a picture of my truck with Bushwacker Pocket Flares. I love them.
I am wanting to install bushwackers on my white f350, do these come with the rubber gasket that goes around the edge of the flare? I seen a set of stampedes that have a rubber gasket that you have to put around the edge, just wondering if bushwackers are like that.
Old 02-05-2012, 01:48 PM
dscabra's Avatar
dscabra dscabra is offline
dscabra is gaining momentum as a positive member of FTE.dscabra is gaining momentum as a positive member of FTE.
Quote:
The Bushwacker flares include the rubber seal for the edge of the flare that fits up against the body of the truck. The seal is very easy to install and has 3M adhiesive on it to keep it from moving.
  #28
Old 02-05-2012, 02:04 PM
dscabra's Avatar
Bushwacker pocket style flares painted body color (from the side):
  #29
Old 02-05-2012, 02:59 PM
barhopper901 barhopper901 is offline
barhopper901 is starting off with a positive reputation.
Quote:
Nothing to add here really, and obviously everyone has their favorite, but personally I have always thought that this is the best looking truck I've come across on this forum. Very Nice! That is all.
  #30
Old 02-05-2012, 03:04 PM
Ian123's Avatar
Ian123 Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
Just curious, what's the point of getting tires that stick out if you're going to cover them with flares anyway?
Front wheel liners with bushwhacker flairs? puckett_jw 2017 Super Duty 0 01-11-2017 07:58 PM
Flair side bed 83capril Ford Truck Parts for Sale 3 04-06-2016 10:43 PM
1980 - 1986 F150 flair side fender kylelang11 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 02-23-2015 01:53 PM
Help choosing bumper colour 2ndStroke 6.7L Power Stroke Diesel 60 04-10-2014 10:48 PM
Short bed Dually podirtfarmer 1999 to 2016 Super Duty 24 09-15-2008 08:52 PM
Tags
06, 97330, bushwacker, chrome, ebay, f150, fender, flairs, flares, ford, make, putco, short, street, taller, trim, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
