Clutch adjustment - Ford Truck Enthusiasts Forums
Clutch adjustment
Old 09-19-2010, 10:20 PM
cabloom300's Avatar
cabloom300 cabloom300 is offline
cabloom300 is starting off with a positive reputation.
Clutch adjustment
I just dropped my old 360/np435 in today. The tranny was tough getting on but i believe it is on right. I had to back off the nuts on the rod for the clutch linkage and realized when i put the rod back on i couldnt see how far i had to go becuase the rod was blocking my view. Right now the tranny seems stuck in gear and i cant get it out. I started it up and i could start to get it to move but only way at the top of the pedal. My question is which way do i need to adjust the nuts to get my rod right? This might be hard to understand but just ask and i can try to clear it up. Thanks
Old 09-19-2010, 10:27 PM
Bullitt390's Avatar
Bullitt390 Bullitt390 is offline
Certified Thread Hijacker
Bullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant futureBullitt390 has a brilliant future
You adjust it for a pedal freeplay of 1"-1 1/2".
Either measure from the floor to the pedal pad or from the steering wheel to the pad.
However, engine off you should easily be able to move the shifter in and out of the gears.
Josh
Old 09-19-2010, 10:32 PM
cabloom300's Avatar
Thats what i was afraid of. What could by my issue there?
Old 09-19-2010, 10:39 PM
Bullitt390's Avatar
Did you have the top plate off at one time? Maybe the shift forks weren't lined up while the tranny was also in gear instead of neutral.
Josh
Old 09-19-2010, 10:42 PM
cabloom300's Avatar
Top plate on the tranny? it was off at one point but it shifted fine just moments before we went to put it in. When i went to put the shifter back on it looks as though its somewhere around 2nd gear. But regardless it doesnt want to move with or without the clutch in.
Old 09-19-2010, 11:02 PM
Bullitt390's Avatar
Pull the top plate and have a look-see.
Josh
Old 09-19-2010, 11:08 PM
cabloom300's Avatar
Alright il have a look. Is it most likely something within the tranny or something having to do with the clutch mechanism as to why it seems stuck in gear?
Old 09-19-2010, 11:50 PM
Bullitt390's Avatar
I would say something to do with the shift forks most likely.
Josh
Old 09-20-2010, 12:00 AM
cabloom300's Avatar
Alright thanks, il look around this coming weekend
Changing clutch '63 ige1963 1961 - 1966 F-100 & Larger F-Series Trucks 1 01-25-2015 11:23 AM
Clutch master cylinder bleed / replace wtroger Ranger & B-Series 0 06-23-2014 06:04 PM
Non Adjustable Clutch Rod? mechelement Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 17 06-03-2013 07:42 PM
Clutch Springs, Z bars, and Other stuff Broomfieldbum 1961 - 1966 F-100 & Larger F-Series Trucks 17 09-05-2012 02:47 PM
Clutch push-rod bushing / clutch adjustment Fordownsall Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 14 06-11-2011 04:26 PM
Tags
1974, 1976, 1979, 4x4, 74, 79, adjust, adjustment, clutch, f100, f250, f350, ford, freeplay, pickup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
