My truck dies at the stoplight everytime - Ford Truck Enthusiasts Forums
Old 09-19-2010, 10:15 PM
waltharper's Avatar
waltharper waltharper is offline
waltharper is starting off with a positive reputation.
yep, always restarts after a pump or two on the pedal and hit the starter and away we go again.
I am thinking I need a new carb. it is the original from 1962. but the truck only has 51,000 miles on it. the guy before me rebuilt it but still.
I am thinking someplace else then NAPA. They wanted $319. For a one barrell, I am thinking that is a bit steep.
maybe any other sugestions. I tested the advance by putting a vacum pump on it and it move back and forth. I did not find any vacum leaks on the carb.
When I ran the air screw in, it Kept running.
I am now looking for any other ideas. This will be a cool little truck once I get the bugs worked out of it.
I check the rear end today and it had a dana 44 with a tag that said to only use limited slip oil in it. I did not open it up yet. but it does sound promising. I wonder what the gear ratio is?
Well any help would be appreciated. Thanks....
Walt
Old 09-19-2010, 11:13 PM
WarOzz's Avatar
WarOzz WarOzz is offline
WarOzz is gaining momentum as a positive member of FTE.
Sounds like at the very least you need a couple new air mixture screws and possibly a carb rebuild kit. If it sat for a long time with gas in it then that carb is probably plugged up. Also have you checked the timing yet? You might try running some seafoam through a vacuum line while it's idling and clean everything out good.
Old 09-20-2010, 12:10 AM
Terry S's Avatar
Terry S Terry S is offline
Terry S is starting off with a positive reputation.
Parts house
RockAuto Auto Parts
this place has pretty fair prices and just about anything you need. I use them sometimes even just for price comparisons.
Old 09-20-2010, 01:07 AM
Old93junk's Avatar
Old93junk Old93junk is offline
Old93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputationOld93junk has a superb reputation
Sounds like you may have a vacuum leak around the throttle shaft in the carb, the bushings may be worn out after 49 years! they can be replaced.........Sounds classic, no matter what you do it will idle poorly and stall after deceleration. Squirt some starter fluid around the carb and listen for RPM increase and you will find the leak, just because someone rebuilt it, does not mean they did it right.......your float level may be messed up, many different things could be contributing here. Take the metal tag off the carb, and go down to Knecht's and get a rebuild kit, should be cheap, and a simple carb to rebuild.
Old 09-20-2010, 03:13 PM
waltharper's Avatar
I think I will just solve the problem by replacing the carb and be done with it.
Old 09-21-2010, 01:02 PM
rhkcommander959's Avatar
rhkcommander959 rhkcommander959 is offline
rhkcommander959 is starting off with a positive reputation.
One barrel carbs can be finicky
Old 10-04-2010, 05:24 PM
waltharper's Avatar
I have replaced my carb and the fuel filter (twice) and the ole girl runs really good now.
Now all I need to do is change out the points for electronic ignition and the water hoses, test for strenght of the antifreeze. she should be good for winter.
Vacum issues weezer4117 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 10 05-08-2013 05:21 AM
86 F350 Timing issues armashby 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 16 08-17-2011 09:14 AM
ERV question??? ewellman Ford Inline Six, 200, 250, 4.9L / 300 4 09-30-2003 01:01 PM
1997 f150 stuck on defrost vent baer17 Cooling, Heating, Ventilation & A/C 2 07-18-2003 02:45 AM
Smog pump and O2 sensor performance questions... lothar 2112 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 11-05-2002 11:21 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
1992, 50, deceleration, die, dies, f150, ford, idle, light, move, stop, stoplight, time, truck, weel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
