Alternator replacement/ How to - Ford Truck Enthusiasts Forums
Old 09-19-2010, 08:27 PM
Reid lariat Reid lariat is offline
Reid lariat is starting off with a positive reputation.
Any ideas or tricks of the trade for changing out a bad alternator. Looks like the air filter hose goes first and then some bolts. Any help would be great.
Old 09-19-2010, 08:37 PM
bridge's Avatar
bridge bridge is offline
bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.
It's real straight forward:
  1. Disconnect the battery.
  2. If equipped with the 4.6L engine, remove the air cleaner outlet pipe.
  3. If equipped with the 5.4L engine, remove the air cleaner inlet pipe.
  4. Rotate the front end accessory drive belt tensioner clockwise and position the front end accessory drive belt aside.
  5. Release the generator harness locator from the generator bracket.
  6. Remove the 4 bolts and the generator bracket.
    • To install, tighten to 10 Nm (89 lb-in) .
  1. Loosen the 2 generator bolts and position the generator aside to access the electrical connections.
    • To install, tighten to 25 Nm (18 lb-ft) .
  1. Disconnect the generator electrical connector.
  2. Position the generator B+ protective boot aside and remove the generator B+ nut and terminal, and remove the generator.
    • To install, tighten to 8 Nm (71 lb-in) .
  1. To install, reverse the removal procedure.
Old 09-19-2010, 08:46 PM
K.O-T.O K.O-T.O is offline
K.O-T.O is starting off with a positive reputation.
Just did mine at 147k. Disconnct battery. Remove Air intake and unbolt radiator shroud. Dont have to remove. Disconnct the radiator hose at the radiator and flop it up toward firewall. Un plug and remove three bolts. Will have to turn to remove. If you havent done so it may be a good idea to replace the cerpintine belt. Recommended every 60k. Also did mine for the first time at 147k. Half hour job. I think it was $250 with a $50 core charge.
Old 09-19-2010, 09:53 PM
Joe04F150 Joe04F150 is offline
Joe04F150 is starting off with a positive reputation.
my battery light just started coming on over the weekend, had the alternator tested and its a dud...getting a new one tomorrow.
Old 09-20-2010, 09:12 PM
Piratetech Piratetech is offline
Piratetech is starting off with a positive reputation.
I would try and find a auto electric shop to rebuild it. The last one I had done cost me 45 dollars and you get alot better product than ships in from china. Keep a local guy in business!
Old 09-21-2010, 02:58 PM
I bought one from a salvage yard today for $70.00. Installed and seems to be o.k. I ran my truck for an hour today and the battery seemed to stay fully charged. Time will tell.
Old 09-21-2010, 05:57 PM
KEVIN IN CHICAGO KEVIN IN CHICAGO is offline
KEVIN IN CHICAGO is starting off with a positive reputation.
Try a police package Crown Vic alternator (Mitsubishi) - bolts right up and way more power (I plow snow) just take Crown Vic from same year.
Second alternator carlhwv 6.7L Power Stroke Diesel 7 11-14-2016 05:22 PM
Alternator wiring question... Tyler S 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 05-04-2014 11:48 PM
Excessive amperage 300amp alternators mr.noodi Excursion - King of SUVs 19 02-15-2013 09:33 PM
High Current Alternator wired directly to battery damonlan 1999 - 2003 7.3L Power Stroke Diesel 22 01-07-2013 02:00 PM
Alternator wiring diagram robjef Electrical Systems/Wiring 3 10-24-2010 05:06 PM
Tags
2005, alternator, belt, bolts, explorer, f150, flathead, ford, generator, licoln, navigator, remove, specs, tighten, tightening, v8, videos
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
