2001 F-150 4.2 AC only works on HIGH
There is a resistor block mounted into the ductwork I think under the passengers side of the dash.This resistor "network" consists of if memory serves 3 large wire wound resistors(Coils of heavy gage wire). These are designed to slow the blower speed down when selected by the Cluster switch.
The reason its mounted into the ductwork,is that they produce a good amount of heat when energized,and the airflow keeps them "cool" to a certain extent.
The connector likely has 3-4 heavy gage wires on it,and it should be held in by 2/3 screws.
Find it,unplug it,and pull it out.I suspect you will see that one or more is broken.
New ones are cheap.Dont bother trying to fix it.
The reason HI works,is because in that position,the resistor block is bypassed,and a FULL 12-14 volts are applied to the blower motor.
Hope this helps...welcome to FTE
Ray Brandin
05-29-2017 07:50 PM
annaleigh
03-22-2017 10:48 PM
