2001 F-150 4.2 AC only works on HIGH - Ford Truck Enthusiasts Forums
Old 09-19-2010, 06:46 PM
badrepp badrepp is offline
badrepp is starting off with a positive reputation.
Help,
When I have the AC on normal the switch setting on 1,2,3 it blows very little air, on 4 it blows out a lot of air. On AC max setting the is nothing out the 1,2,3 settings but 4 blows a lot of air.
New to the Ford work - any ideas
Bob
Old 09-19-2010, 07:05 PM
n5926g's Avatar
n5926g n5926g is offline
n5926g is starting off with a positive reputation.
There is a resistor block mounted into the ductwork I think under the passengers side of the dash.This resistor "network" consists of if memory serves 3 large wire wound resistors(Coils of heavy gage wire). These are designed to slow the blower speed down when selected by the Cluster switch.
The reason its mounted into the ductwork,is that they produce a good amount of heat when energized,and the airflow keeps them "cool" to a certain extent.
The connector likely has 3-4 heavy gage wires on it,and it should be held in by 2/3 screws.
Find it,unplug it,and pull it out.I suspect you will see that one or more is broken.
New ones are cheap.Dont bother trying to fix it.
The reason HI works,is because in that position,the resistor block is bypassed,and a FULL 12-14 volts are applied to the blower motor.
Hope this helps...welcome to FTE
AC stops working once in a while ugh3012 Cooling, Heating, Ventilation & A/C 8 03-16-2017 11:16 AM
blower motor 2010 stx f150STX27 New Member Introductions 1 04-21-2016 04:33 PM
AC Blowing Hot Air 1L243 Cooling, Heating, Ventilation & A/C 3 06-30-2015 09:30 PM
air blows out a/c vents all the time plywood50 2004 - 2008 F150 14 04-12-2011 05:34 PM
Air only blows out of defrost kevinwebster1 1999 to 2016 Super Duty 5 10-21-2009 06:15 PM
Tags
1999, 2001, 2005, ac, air, block, blows, conditioner, escape, f150, ford, high, resistor, truck, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
