Standard speaker size in a 1999 F-350 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 09-19-2010, 02:25 PM
neumayr83 neumayr83 is offline
neumayr83 is starting off with a positive reputation.
I drive a 1999 F-350 Crew Cab. I just finished installing CS-AT1100 fusion active bass tube. I went and showed my dad and he turned the bass all the way up in the regular truck speakers and ended up blowing the speakers in about two seconds, so now I have to fix those but before I start anything I just want to know what the standard speaker sizes are. I believe they are 6" x 8" but I'm not sure.
Thank you,
Barry
Old 09-19-2010, 02:46 PM
CRF1966's Avatar
CRF1966 CRF1966 is offline
CRF1966 is starting off with a positive reputation.
<DL hasbox="2"><DT class=speakers hasbox="2">Front speakers Front Door: 6x8" For rear speakers Behind Seat: 6x8" </DT></DL>
Old 09-19-2010, 04:21 PM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
I ordered these for my truck. I bought 2 pairs with the Ford wiring harness connectors. Install was pretty easy and the speakers sound great.
Kenwood KFC-C6893PS 6"x8" 3-way car speakers at Crutchfield.com
Old 09-20-2010, 12:32 AM
Thank you very much!
and Greg, are you saying you got the fusion 6 x8s? That is the kind of speakers I would want to get so I can keep the fusion speakers through out the truck
Old 09-20-2010, 12:23 PM
No, I purchased a set of Kenwood speakers from Crutchfield and they were a direct bolt in replacement (front and rear). The mounting holes lined up and there were no modifications required to make them fit. They even shipped with the special wiring harness connectors so the speakers would plug right into the Ford wiring. If I remember correctly, they even send some installation instructions with photos so the install was pretty easy. Took about 30 minutes.
I am not familiar with the Fusion brand of speakers, they may have a larger magnet base and could have some clearance issues. Perhaps you can look at the link I provided and copy down all the dimensions and cross reference to the brand you are looking at and see if they are the same basic size. If so, then they will probably fit.
Good luck. Hope this information is useful.
Back speakers only produce bass! No vocals! Nathan00 Electrical Systems/Wiring 1 12-19-2014 09:51 PM
Speaker question Penn79 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-04-2013 06:28 PM
Super Duty with Supercab Buck268 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 5 04-03-2013 09:14 AM
Radio/ speakers not working neumayr83 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 10-08-2011 10:50 PM
Speaker Problems TallPaul Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 15 08-06-2009 09:39 PM
Tags
1999, 2000, 350, csat1100, diesel1999, f250, f350, fusion, replacement, review, size, sizes, speaker, speakers, standard, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
