DTC CODES
DTC CODES
Hi, these are the codes I pulled from an 05 F-350 6.0 - Any thoughts?
#1 P2285 - Injector control pressure sensor circuit Low
#2 P0403 - Exhaust gas recirculation control circuit
#3 P0405 - Exhaust gas recirculation sensor A circuit low
#4 P0113 - Intake Air Temperature sensor 1 cicuit High Input
#5 P0403 - same as above
#6 P0405 - same as above
#7 P2285 - Injector control pressure sensor circuit low
Any Ideas? Short or wire chafing somewhere?
Won't start
<!-- / message -->
Won't start
<!-- / message -->
Looks like you have two threads going on the same issue.
SteveBricks advised you to unplug the ICP and it did not help w/ the no-start.
Look into the IAT1.
Also, in the Tech Folder is a "no-start" troubleshooting thread that can tell you how to measure the high pressure oil pressure from the ICP voltage.
Look into the IAT1.
on
Why did you start two threads for the same problem?It would be easier on those with the time to help you if you posted once.IAT1 is intake air temperature do you have an aftermarket oiled intake filter?At the top of the forum there is a tech folder read it and you will learn a ton,this is the sensor you are getting a code for Page 59: Electrical Components
