brake booster upgrade? swap? stock?
Hey ford-fans,
1975 F250 4x4, 360cid, 4sp manual, Dana 44hd/ Dana 60. DRUMS ALL AROUND
It seems my brake booster has taken a dump. Luckily I can still stop, by standing on the pedal. I just wanted to know if there is a booster/master setup that will provide better braking action than the stock one.
A couple things (if they are a factor):
-I have found a dana 60 front and dana 70 rear (that if i can get my hands on) ill be swapping in...
-I plan on eventually doing the rear disc swap.
so is there a better booster/master that will fit now and work for that setup? (like a one ton booster/master?)
thanks ford-fans
thanks ford-fans
Doing the rear swap is pretty easy from what I get. It uses mid-80's chebby front one ton disc brakes, mounted with a steel bracket.
72-79 Ford DANA 60 Rear Disk Conversion: Off-Road.com
And you just have to change the PROP valve.
http://http://www.wildhorses4x4.com/...isc_Brake_Kits
Finally it was suggested to get a bigger booster and MC
Doing the rear swap is pretty easy from what I get. It uses mid-80's 75--87 Chevy K-20, 3/4 ton, 4X4 caliber, if you don't mind deleting the ebrake. I have a thread going 'ebrake with disc swap' where you can read about alternatives. chebby front one ton disc brakes, mounted with a steel bracket.
And you just have to change the PROP valve. If you have disc up front, you shouldn't need to change the valve. With drums only, buy a wilwood adjustable v. for rears only.
http://http://www.wildhorses4x4.com/...isc_Brake_Kits That link is dead.
no! the master has to match the truck! if your changing to the one ton stuff, change to the dual diaphram master/booster. i've had less than satisfactory performance when my stuff doesnt match. if your switching to the dana 60, i would get the booster/master from a 75 f350 2x4 (dual diaphram) to feed it.
ok... now im confused.
f-250 restorer says yes 78 f350 dual diaphram booster and master
highboy1975 says no.
I have a 75 f250 drum all around. 4x4, with 1 ton axles (dana 60 full float and dana 44hd 3500lb kingpin front) the back drums are 12x3 (off of f350) and the fronts are stock
will it work? will it be better? or will it be worse?
candoo
07-05-2014 10:26 PM
ridemx
05-29-2011 05:20 PM
