'85 Bronco tailgate window issues with unique workaround - Ford Truck Enthusiasts Forums
1978 - 1996 Big Bronco SPONSORED BY:
Old 09-18-2010, 10:28 PM
js.baker09's Avatar
js.baker09 js.baker09 is offline
js.baker09 is starting off with a positive reputation.
I recently joined the forum, and this is my first post. Anytime I've had an issue with my Bronco, Google typically lead me to this site; so I figured why not join because the best advice I've received has come from here.
The rundown:
The tailgate window stopped responding to the key and the switch in the cab. I took off the access panel, pulled the motor, and discovered the motor was bad. Bought a new one and installed it; issue still remained. Saw advice on here about the safety relay in the gate, so I bypassed that by crossing the wires; issue still remains. I poked under the dash checking out the switch, but both grounds are secured. Frustrated at the situation, I've come up with a better idea, or so I think.
I want to bypass all the nonsense going on by running two wires from the lift motor all the way to the battery with a switch in the cab that activates the window up/down. How could I go about doing this?
Old 09-18-2010, 11:28 PM
g_k50 g_k50 is offline
g_k50 is gaining momentum as a positive member of FTE.g_k50 is gaining momentum as a positive member of FTE.
Does the switch in the tailgate work the motor?
Did you check the fuses?
Didn't Ford spend alot of money engineering the tailgate window already?
Why reinvent the spoon?
Old 09-19-2010, 12:04 AM
js.baker09's Avatar
The switch is supposed to work the motor, but as of right now, there's just the sound of the click, no motor activity.
I replaced all the fuses about two months ago when the blinkers were having issues. I rechecked the fuses, and just for the sake of it, I replaced the fuse.
I suppose Ford did spend a lot of money engineering the tailgate window, but their completed design will ultimately cause me to spend a lot of money getting someone else to fix it.
Maybe I don't like spoons, maybe I want to eat with sporks instead.
Besides, I feel that this simplistic design would work in my advantage, I'll lose the function of rear switch, but won't spend 6 hours trying to figure out what's going on just to find out that the ground in the dash came loose (which isn't the case here unfortunately).
Old 09-19-2010, 12:08 AM
Is the window operating at all?
Is it stuck up or down? I'm thinking that the regulator needs to be lubed.
Old 09-19-2010, 12:15 AM
js.baker09's Avatar
The window was stuck up until I spent a few hours at all weird angles pulling the motor out and pushing down the window. When I connect the motor to the battery, everything works fine. As it is right now, the access panel is off, tailgate is up and I ran wires from the motor through the cab to the battery just so I could close the window (tailgate latches don't engage).
Old 09-19-2010, 12:17 AM
Do you really need wires? Don't you just need power to the motor? and then ground is the frame? Put a switch in the wire and bob's your uncle. Next please.
Old 09-19-2010, 12:21 AM
js.baker09's Avatar
I'm talking about loose wires, not the engineering's design. There's something going on with their design that's shorting out and I can't find it.
So far I have figured out, Hot to Hot, window goes up, Hot to Ground, window goes down. I don't know what kind of switch I would need or how to wire it in order to ghetto-rig this.
Old 09-19-2010, 07:00 PM
Suppoko Suppoko is offline
Suppoko is starting off with a positive reputation.
I had the same problem and found that it was the tailgate latch switch that was bad, I jumped it to itself bypassing the latched requirement and it works fine.
Old 09-19-2010, 10:08 PM
js.baker09's Avatar
How did you/could I do that? I already bypassed the relay by crossing the wires, and I know the regulators are fine since the window moves up and down if I connect the motor directly to the battery. I'm looking for the easiest way to get this fixed; so far wiring a direct switch in the dash is the best option in my opinion so far.
Old 09-19-2010, 10:42 PM
sdg0080's Avatar
sdg0080 sdg0080 is offline
sdg0080 is starting off with a positive reputation.
i just messed with a buddy's 88 for over a solid day. all to find out it was corrosion in the harness connector between the tailgate lock switch and the motor. check that. we had to end up cutting it and hard wired it together...so no more plug connector. now it works great. and as far as using the chassis as ground. a DC motor reverses polarity to go up or go down. so you need two wires run to it. you would need a power window switch that will cross over ground and hot depending if you want up or down. just about any window switch will work for what you want.
Old 09-19-2010, 11:02 PM
js.baker09's Avatar
Do you have a diagram available I could look at because I don't really want to electrocute myself. I haven't really had experience wiring things that required a ground, most of my experience is just replacing wires or what not.
Old 09-20-2010, 01:21 PM
sdg0080's Avatar
no i dont have one. its pretty simple. most switches will have 4 posts on the back. all they do is reverse power and ground. i'd really check that harness connector in the tailgate before you dive too far into this. like i said i spent a while checking electrical on my buddys 88 and i about pulled my hair out when i found out it was simple corrosion.
Old 09-20-2010, 01:31 PM
kpoyner kpoyner is offline
kpoyner is starting off with a positive reputation.
I am having kind of the same problem with my 95. i can get it to roll down but then I have a hard time rolling it back up. Any suggestions
Old 09-20-2010, 04:15 PM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
Slow operation in one direction is typically indicative of misalignment or a gummed up regulator. Cleaning the regulator by degreasing and applying a light coat of lithium grease to those glide and pivot points will help immensely. A serious word of caution though... NEVER apply lubricants to the window glass or the side tracks.
Ok, guys, all the talk of putting in new switches or relocating and running new wiring begs the question that g_k50 already posed... Ford already engineered this part of the electrical system.
Keep in mind that the tailgate glass circuits are NOT fused. Circuits 12 and 14 use automatically resetting circuit breakers. If they trip and don't reset after a while, either the short circuit/overload condition continues to exist or the breaker needs replacing.
Old 09-20-2010, 05:31 PM
sdg0080's Avatar
hey i agree that ford did a great job with the engineering part of it. concidering the first thing my professor taught us about an engineer. "An engineers job is to take a simple task...and make it impossible" the set up is really impressive in its simplicity. once i figured out it was corrosion on the plug in connector the "fix" went great. although i will say the wires from the body over to the tailgate leave something to be desired. i assume its common for the wires and loom to break at this point.
Tailgate Window Lift Key Switch Bypass? 78Ranger_Bronco 1978 - 1996 Big Bronco 26 05-19-2016 04:47 PM
1996 bronco, tailgate window issue kirby1111 1978 - 1996 Big Bronco 10 03-16-2016 10:10 AM
One power window will go up but not down mikentucky Excursion - King of SUVs 6 03-04-2015 03:14 PM
Bronco tailgate motor fordka 1987 - 1996 F150 & Larger F-Series Trucks 4 06-25-2014 04:52 PM
Tailgate window not going down even after various attempts to repair it. TicoTube 1978 - 1996 Big Bronco 19 05-03-2013 04:03 PM
Tags
150, 84, 86, 96, bronco, diagram, ford, fuses, hardwire, key, latch, linkage, motor, replacing, switch, tailgate, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
