'85 Bronco tailgate window issues with unique workaround - Page 2 - Ford Truck Enthusiasts Forums
Old 09-20-2010, 07:17 PM
js.baker09's Avatar
js.baker09 js.baker09 is offline
js.baker09 is starting off with a positive reputation.
I agree entirely that the Ford engineers did a great job with the electrical wiring, but I've already made up my mind in deciding to do this; seeing as how I have already ran the wiring from the motor and through the cab. At this point, I'm so frustrated with the tailgate that I would much rather do it this way than squeeze my arms at weird angles to access the wires.
Old 09-20-2010, 07:46 PM
sdg0080's Avatar
sdg0080 sdg0080 is offline
sdg0080 is starting off with a positive reputation.
cool so then just pick up a power window switch. grab an ohm meter and go to town
Old 03-21-2013, 11:33 AM
Robert Hampton Robert Hampton is offline
Robert Hampton is starting off with a positive reputation.
I have a 96 and my rear window went down but wont go back up neither switch works I look for the safety switch and cant find it or is it a relay somewhere I should check help
Old 03-21-2013, 08:13 PM
FourXFord2's Avatar
FourXFord2 FourXFord2 is offline
FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.FourXFord2 has a good reputation on FTE.
I have had difficulties with t-gate wiring before, A reall PITA, but not as hard as you make it seem. Starting behind the drivers tailight, check to make sure you have no open wires on the bigger wires. If you can move the harness around and make the ohms reading change it's a broken wire or bad connection in between. For testing purposes I've closed the latches with my finger or a screwdriver, if the safety switch is open when the latches are closed and the meter indicates open, change the switch. If there is continuity across that it could be in the key switch at the t-gate.
I found a bad connection between the wiring coming from the body, right behind the connector, body side. I replaced the wire affected, it splices near the bumper as well on my '91. This high resistance through the connection was making the window go up really slow. Remember a switch only has 2 positions, open and closed. If they check open in both positions, change them. If I can find my Haynes manual I'll look for a diagram and see if I can figure out possibles or what you should find when checking the wires with a test light.
Old 08-27-2014, 01:22 AM
Auminer's Avatar
Auminer Auminer is offline
Auminer is starting off with a positive reputation.
Quote:
A serious word of caution though... NEVER apply lubricants to the window glass or the side tracks
Can you tell us why?...what happens, does it cause the glass to stick more?
Thanks,
tailgate safety button/sensor etc window stuck up Berardini2121 1978 - 1996 Big Bronco 2 06-22-2016 02:12 PM
1996 bronco, tailgate window issue kirby1111 1978 - 1996 Big Bronco 10 03-16-2016 09:10 AM
Tailgate window not going down even after various attempts to repair it. TicoTube 1978 - 1996 Big Bronco 19 05-03-2013 03:03 PM
96 bronco rear window motor...really on my last nerve mikeismadness 1978 - 1996 Big Bronco 21 07-27-2011 02:29 PM
another tailgate question mikefraz01 Electrical Systems/Wiring 4 10-23-2002 02:39 PM
Tags
150, 84, 86, 96, bronco, diagram, ford, fuses, hardwire, key, latch, linkage, motor, replacing, switch, tailgate, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
