Intermittent Ignition Problem - Ford Truck Enthusiasts Forums
Old 09-18-2010, 09:50 PM
shamusliam shamusliam is offline
shamusliam is starting off with a positive reputation.
78 f150 4 wheel drive, 351m. Too ugly to show a picture of it. I have a problem with the truck not starting sometimes. Starting easy, running and then cutting off. Ran one day long enough for me to make two trips to the dump with no problems. When it is playing the I'm not going to start game, it seems to fire when I let off the ignition switch. I have found a wire coming off the ignition switch that was frayed, fixed that. Replaced the coil wire (it was not conducting). Replaced the ignition switch, hard wired the ignition module and replaced the coil horseshoe connector. It still just craps out sometimes and then won't start. It can be cold, hot, it doesn't really matter. It is very frustrating, please help. I do not have a test light but do have a multi meter.
Old 09-18-2010, 10:13 PM
steponit steponit is offline
steponit is gaining momentum as a positive member of FTE.
Check the plugs on the distributor.
Sometimes they fray or corrode causing intermittent running
Old 09-19-2010, 01:23 AM
4x4 Bart 4x4 Bart is offline
4x4 Bart is gaining momentum as a positive member of FTE.
Have you tried a different ignition module, This would be my first suspect.
Old 09-19-2010, 09:59 PM
do you mean the connector from the icm to the distributor, the one with the three wires?
Old 09-20-2010, 12:43 AM
76Hauler's Avatar
76Hauler 76Hauler is offline
76Hauler is gaining momentum as a positive member of FTE.76Hauler is gaining momentum as a positive member of FTE.
my 76' had the factory electric ignition, i'm guessing the duraspark. I had some of your same problems, I fixed it with a MSD 6al ignition.
Old 09-20-2010, 02:07 AM
sradams21 sradams21 is offline
sradams21 is starting off with a positive reputation.
Smile
I had the same problem start with my 74 F100 with the duraspark electronic ignition. It turned out to be the ignition pick-up in the distributor went bad but not before taking the ignition box with it. It cost me a who woppin $53.00 to replace the pick up and box from O'reileys/Checkers.
Old 09-20-2010, 02:08 AM
Smile
Its worked perfectly since. Made the 1030mile drive front Denver, CO to south Houston, TX flawlessly.
76 F100 Ignition issues corkel Electrical Systems/Wiring 1 08-01-2014 03:19 PM
76 Ford F100 Ignition troubles corkel 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-20-2014 10:54 PM
Dura spark troubles mntnbikr 1973 - 1979 F-100 & Larger F-Series Trucks 53 05-14-2007 01:18 PM
Popping Ignition Switch 78BamBam Electrical Systems/Wiring 2 08-15-2004 05:43 PM
Ignition problems (Switch ?) youngAZfordguy 1973 - 1979 F-100 & Larger F-Series Trucks 16 08-12-2004 11:27 AM
Tags
1976, 1977, 1994, 49, control, duraspark, f150, ford, frayed, ignition, ii, intermittent, module, pickup, problem, spark
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
