1979 F-350 4x4. How rare? - Page 2 - Ford Truck Enthusiasts Forums
Old 09-19-2010, 08:20 PM
fordtrucknut's Avatar
fordtrucknut fordtrucknut is offline
fordtrucknut is starting off with a positive reputation.
Not neccesarily..4 speeds were fairly common...it's the 460 that was NON existent in a 4x4...if it has a 460...it's not original....my 79 F-350 4x4 is a 4 speed truck...but has had a 460 swapped in...it came with a 351M or 400...(Not sure which one...don't have VIN handy..LOL)...Nice score..put up some pics so we can see it or have someone help you get some pics up!!
Old 09-20-2010, 12:07 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Farmer Bob 509 View Post
The one i have has got a 4 speed manual, does that mean that someone put it somewhere down the line?
1979 F350 4WD: Two different 4 speed manual transmissions were available, New Process 435 & Warner T-18, but...
There were no F350 4WD's available with a 460 engine or with a manual transmission until 1983.
1979 F350 4WD: C6 Cruise-O-Matic only with either a 300 I-6, 351M 2V or 400 2V.
The TRANS code is listed on the Warranty Plate, located on the left door face below the latch.
A = New Process 435 / F = Warner T-18 / K = C6 Cruise-O-Matic.
The engine code is the 4th digit of the VIN. 1979 F350 4WD =
B = 300-I-6 / H = 351M 2V / S = 400 2V.
If your 1979 F350 4WD has a 460 w/a 4 speed, both were swapped in.
460: 1973/79 F100/350 2WD's only.
Old 09-21-2010, 09:59 PM
351coupe 351coupe is offline
351coupe is starting off with a positive reputation.
Quote:
There were no F350 4WD's available with a 460 engine or with a manual transmission until 1983.....................
This post kind of contradicts itself in the first 2 lines...'79 F-350 4wd,2- 4 spds available...then F350 wasnt available with 460 OR 4spd until '83.I believe that OR should be an AND.
'79 F-350 4wd were DEFINITELY available with a 4 speed(NP435)behind a 351M or 400.I have one which is 100% factory,and Ive had a couple of others.
As to the original posters question...I dont have the numbers,but ANY '79 F350 4x4 is a fairly rare truck.Much less common than any 73-79 Reg Cab F-150/F-250 4x4.
Your's being a Super Cab...I would say its a little more rare than a 78-79 F250 4wd Crew Cab...and probably just as desirable.
Nice score!!
Old 09-22-2010, 12:21 AM
steponit steponit is offline
steponit is gaining momentum as a positive member of FTE.
Read it again Numberdummy is correct
The word Then should be, 'the'
Old 09-22-2010, 07:44 AM
Quote:
'79 F-350 4wd, 2- 4 spds available...then F350 wasnt available with 460 OR 4spd until '83. I believe that OR should be an AND.
There in no contradiction of any kind.
As I clearly stated, there were two 4 speeds available (I even listed the types and the Warranty Plate TRANS codes), but...
You could not get a 460 engine with 4WD or w/a manual transmission until 1983.
Ergo: The two 4 speeds were used with the: 300 I-6, 351M & 400.
Old 09-22-2010, 08:25 AM
chrlsful's Avatar
chrlsful chrlsful is offline
chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.
Could the frnt end been swapped in? May B the tag's off. No 1 can tell what's transpired over the years unless runnin all the prt #s. I think that's why so many try to get em "back to stock" (all mixed up prts. I'm only 1 guy but I say: "So what"). I forget the initial question, it's gone over a new page & is not available to me here...importance is : Whadda you have for an end goal? Wanna have a pristeen truck w/ a purple frame U can jack up to show your buddies? Wanna go wheeling? Wanna make some money haulin, towin, plowin? All's good 2 me.
Old 09-23-2010, 11:41 PM
This is where I think people are getting confused...79 F-350 4x4's did come with 4 speeds available....but only behind 300 I-6, 351M & 400...as Bill stated....Usually when people swap a 460 in to a truck...say one that originally had a 351M in it....they JUST swap the 460 in.....this can be done...and is all the time...I don't have the specifics on all that is needed...although I know quite a bit (My buddy put one in a 77 F-250 in place of a 400...but his truck was an Automatic)....What Bill is saying is 460 and 4 speed not available...but just because the 460 wasn't available...doesn't mean that the 4 speed wasn't either....hopefully this makes sense to most of you...Originality no...swapped in yes....LOL
Old 09-24-2010, 01:26 AM
Broncodawg's Avatar
Broncodawg Broncodawg is offline
Broncodawg is starting off with a positive reputation.
"There were no F350 4WD's available with a 460 engine or with a manual transmission until 1983."
Sorry number dummy, but this statement is incorrect unless you switch the "or" for "and" as 351coupe already stated. With "or" in there it means "No f350s were available with a manual trans.......and so on and we all know you don't mean that, so....just sayin'. End of grammar session.
Old 03-29-2011, 12:05 AM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
"You could not get a 460 engine with 4WD or w/a manual transmission until 1983."
I came back and re-read this thread. The statement Bill was trying to make was that any Ford truck with a 460 had an automatic transmission until 1983, then the 460 had a manual transmission as an option. The 4x4 didn't have a 460 until 1983, as an engine option.
Since both these hold true, that means no F350 4x4 prior to 1983 had a 460. No 2wd F350 w/460 had a manual transmission prior to 1983.
Old 03-29-2011, 12:39 AM
Aaron-71's Avatar
Aaron-71 Aaron-71 is online now
Aaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to beholdAaron-71 is a splendid one to behold
Lol, some of you people on here are just too damn picky. Number Dummy was nice enough to supply all of the information, and everyone goes on and on about how 1-2 words could be possibly wrong....
Jeez, i sure don't see a lot of gratitude on here... just saying, show a little respect... we all make mistakes...
Old 03-29-2011, 03:09 AM
radar457's Avatar
radar457 radar457 is offline
radar457 is starting off with a positive reputation.
I have 4 of them...one dually..not sure its factory , but a dually none the less...
Old 03-29-2011, 09:52 AM
whistle1516's Avatar
whistle1516 whistle1516 is offline
whistle1516 is starting off with a positive reputation.
All hail numberdummy! The guys a genius with fords!
  #28
Old 03-29-2011, 11:20 AM
Aaron-71's Avatar
Quote:
Precisely. I think his guru-like knowledge with Fords is easily appreciable.
  #29
Old 03-29-2011, 12:44 PM
peganit2's Avatar
peganit2 peganit2 is offline
peganit2 is starting off with a positive reputation.
Dang make a federal case out of of it! I understood perfectly well what he was saying, but then again I'm not a school marm.
  #30
Old 03-29-2011, 12:55 PM
nkapphahn's Avatar
nkapphahn nkapphahn is offline
nkapphahn is gaining momentum as a positive member of FTE.
Cherry 1979 F-350 Ford pickup
Not sure how rare they are, but I'd sure like to own this one
B Code uncleshepard's69 1973 - 1979 F-100 & Larger F-Series Trucks 8 10-28-2015 12:20 PM
Rarely of a 1964 F250 4x4 Flareside Glazefreak 1961 - 1966 F-100 & Larger F-Series Trucks 2 10-24-2015 11:52 AM
How rare? GM4WALLS 1973 - 1979 F-100 & Larger F-Series Trucks 12 11-01-2013 04:46 PM
Searching for specific truck, is it a pipe dream? Rubenk 1973 - 1979 F-100 & Larger F-Series Trucks 12 06-24-2012 02:47 PM
How Many 1956 F250 Duellies Made??? poolpro51 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 01-06-2011 09:18 PM
Tags
0873494113, 1979, 350, 4x4, cab, f350, f3504x4, ford, isbn, lariat, made, ranger, rare, reg, truck, wanted, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
