Antifreeze
Antifreeze
Rich,
Diesels vibrate quite a bit while running and froth the coolant flowing around the cylinders. These bubbles within the coolant, because of the vibration of the engine, smash against the outside of the cylinder walls with a force of several hundred ( and I think a little over a thousand) psi. Over time, the iron of the cylinder wall is blasted away to the point that pinholes occur within the cylinders which allow coolant to enter the interior of the cylinder wreaking havoc with many engine parts and costing a lot of money to repair or replace.
The coolant additive actually coats the surfaces of the cylinder walls so that the air bubbles smash against it instead of the cylinder's iron.
Ford has an additive called FW-16 and I'm sure they have a test strip for it but don't have any first hand experience.
Fleetguard has a coolant additive called DCA4 and they have test strips for their formulation.
Penray has a coolant additive called Pencool and I'm sure they have a test strip for theirs also.
NAPA has a coolant additive call NapaCool and they have a test strip for it. I personally use it.
It is my understanding that you can't mix any of these additives together nor can you use test strips from one on another.
Considering the headaches and money on major engine repairs saved by adding this insurance to the coolant, I think it is money well spent.
R.A.
R.A.
Antifreeze
This info is only as good as its source. When Ford came out with the "Premium Gold Coolant" I had asked a Ford instuctor on their Ford training site if it was still nec to add the FW16 , his reply...No. It is no longer printed (that I have found) in your owners manual that you should add the FW16. A diesel can/will cavitate over time. The Gold Coolant must have additives to it already, just flush and fill on a regular basis. Go under your "severe duty" mantenance schedule, as thats what fits most drivers habits/conditions. Good Luck
Antifreeze
Aw crud,
In my effort to help, I instead mis-informed and confused. I own an idi and am used to the "standard" green anti-freeze and adding a supplemental nitrile solution. I plain forgot that the newer powerstrokes are sold with the orange anti-freeze installed.
Guess I'll just slink away now........sorry............sorry...............
Antifreeze
the pinholes in the cyl sleeves are caused by static electricity, not air bubbles. john deere had a prob with this with thier heavy equipment years ago, and the servicebulliten said to add the additive and to install another ground strap from the motor to the chassis to correct the problem
eden
eden
