Converted 1997 F-350 7.5 460 to Sequential EFI - Dyno Graphs Inside - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 07-01-2012, 10:37 PM
jonbar87's Avatar
jonbar87 jonbar87 is offline
jonbar87 is starting off with a positive reputation.
Ballertown Motorsports • Login
The thread detailing the install^^. If you have any questions just refer to it or you can just ask me. You'll need to create an account to view that thread.
  #32
Old 10-11-2013, 10:26 PM
Forger Forger is offline
Forger is starting off with a positive reputation.
I know this is an old thread but I'm hoping to catch your attention more than anything. I have a 97 with the 7.5, and I'm doing some exercises in seeing what I can get out this thing on pump gas (benefits of army paycheck and being single). I have the RHP Heads (non pollution grind), cam, and intake man. Hedmen header (I know crappy, but I'm looking into the banks header back system. I know everyone says L and L but the banks is bolt up and bench tested so I figure going with them the whole route is better). I took two different intakes and cut them up into a cold air that runs above each wheel well. Bumped the timing up to 12* and am running a BBK Adjustable FPR at 41psi. Since I can't seem to find a bolt in chip that will do anything, and I've read about the whole switching it over to MAF, and now SEFI, I'm wondering how I can do this? I've read use this and that and the other computer and harness (anything with a 5.0 after 96 seems to be common) but my question is since there is no Cam or crank shaft sensor how accurate can this really be? Also, Is there dumb *** style instructions for either of these conversions (SEFI/MAF)? Most of the ones I see are pretty electrical knowledge intensive, and I'm just sitting here going Duh I like spaghetti!
  #33
Old 10-11-2013, 10:33 PM
jonbar87's Avatar
Quote:
Unfortunately the site that I did the writeup on looks to be down so I can't refer you to that. However I do know that as long as you use a MAP sensor, make a SEFI harness and repin the ECU like I did it would work. I still have all the wiring and sensor for when I did mine. I took it all out right before it got stolen. I might be able to find some of the wiring diagrams I used but unfortunately all the ones I documented the new wiring on was in the glove box when the vehicle was stolen.
  #34
Old 10-13-2013, 09:14 PM
Okay. So whats this I've read about being able to use the computer for 4.6? Far as Ifigure you cant because a 4.6 has a crank and cam sensor, and generally cars don't run if they don't detect those.
  #35
Old 10-13-2013, 09:21 PM
jonbar87's Avatar
That I dont know. I just used an AEM Computer. However I wouldn't recommend it since I don't think you could tune it anyway...
  #36
Old 10-13-2013, 10:01 PM
85lebaront2's Avatar
85lebaront2 85lebaront2 is offline
Old School Hot Rodder
85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold85lebaront2 is a splendid one to behold
There is a gentleman in Sweden who converted a 351C to EFI with coil packs like a 4.6L or 5.4L. I did some digging and found that the early 5.4L engines came with the E4OD and coil packs. The crank sensor can be fabricated as he did and the cam sensor was adapted from a 3.8L V6.
Converted 1997 F-350 7.5 460 to Sequential EFI - Tuned with AEM - Dyno Graphs Inside jonbar87 Computer Chips & Tuners 4 04-30-2012 01:56 AM
Pro Comp Traction Bars vs. One Up Off Road Traction bars vs. All Spring Lift jonbar87 Offroad & 4x4 40 09-05-2011 10:40 PM
Like New Toyo Open Country M/T 35x12.5R20 tires for sale jonbar87 All Other Items for Sale 0 08-17-2011 09:43 PM
1996 -97 7.5L 460 F-350 EEC-IV Powertrain Control Module (PCM/ECU) Pinout jonbar87 1987 - 1996 F150 & Larger F-Series Trucks 0 08-29-2010 06:30 PM
1996 - 97 7.5L 460 F-350 EEC-IV Powertrain Control Module (PCM/ECU) Pinout jonbar87 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 08-28-2010 05:21 PM
Tags
1999, 460, 75, bank, cardone, chevrolet, conversion, dyno, f350, fire, ford, injector, jonbar87, sefi, sequential
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
