4r100 Check Ball Locations on Accumulator Plate - Ford Truck Enthusiasts Forums
Old 09-18-2010, 04:46 PM
danspears1 danspears1 is offline
danspears1 is starting off with a positive reputation.
Removed Accumulator body on 01 X trans to remove/replace solenoid pack. Despite being very careful not displace the check *****, they are now out of place. There are four (2 each of 2 different sizes.
I have searched the forum thoroughly, but haven't been able to find a diagram detailing their proper locations. Some have recommended using the instructions from a transgo shift kit, but I couldn't find a link to those either.
Please either provide me a diagram or link to another thread with the information. Thanks, Dan
Old 09-18-2010, 05:10 PM
JMac444 JMac444 is offline
JMac444 is starting off with a positive reputation.
NOTE: Apply a small amount of petroleum jelly to each check ball prior to positioning them on the valve body separator plate.
Install eight rubber and one steel EPC check *****.
<TABLE border=1 cellSpacing=0 cellPadding=3 width="70%"><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1</TD><TD></TD><TD>EPC steel check ball</TD></TR><TR vAlign=top><TD>2</TD><TD>CB6</TD><TD>Check ball</TD></TR><TR vAlign=top><TD>3</TD><TD>BS1</TD><TD>Ball shuttle</TD></TR><TR vAlign=top><TD>4</TD><TD>CB9</TD><TD>Check ball</TD></TR><TR vAlign=top><TD>5</TD><TD>CB14</TD><TD>Check ball</TD></TR><TR vAlign=top><TD>6</TD><TD>CB1</TD><TD>Check ball</TD></TR><TR vAlign=top><TD>7</TD><TD>BS3</TD><TD>Ball shuttle</TD></TR><TR vAlign=top><TD>8</TD><TD>CB8</TD><TD>Check ball</TD></TR><TR vAlign=top><TD>9</TD><TD>CB7</TD><TD>Check ball</TD></TR></TBODY></TABLE>
hope this helps if you need anything else let me know!
Old 09-18-2010, 06:20 PM
Stewart_H's Avatar
Stewart_H Stewart_H is online now
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
See if this Transgo scanned instruction sheet helps.
http://www.ford-trucks.com/forums/73...ml#post6111578
Stewart
Old 09-18-2010, 06:23 PM
Stewart_H's Avatar
He doesn't need the part numbers bro, he's not ordering check *****. He needs a diagram of their location.
Does any of the paperwork you have, from where you got those part numbers, have a diagram of where the check ***** need to be placed?
If you can find that and post it up, that's what the OP is looking for.
Stewart
Old 09-19-2010, 11:36 AM
Thanks for the clarification Stewart_H.
I need a diagram showing the location of the four check ***** on the calibration plate directly above the accumulator, not the plate above the main valve body. I was able to find that. For some reason, the instructions I found regarding removing/reinstalling the accumulator and plate do not mention the checkballs at all.
Please help me. I gotta get the X back on the road.
Old 09-19-2010, 08:23 PM
Stewart_H's Avatar
Dan, I bet someone in the 7.3L forum has the answer you're looking for.
Post up over there!
Stewart
Old 09-19-2010, 09:03 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
I had a similar experience with my 4R70 in my Mark VIII and the only way I found was to look for the shiney spots where the ***** seated. It worked for me, maybe I just got lucky.
Old 09-20-2010, 12:30 AM
ajorn's Avatar
ajorn ajorn is offline
ajorn is starting off with a positive reputation.
Here is a link to the pictures from mueckster....I've been there with the check *****. Use vasoline and you'll be good. BTW, I lost one and called the local Ford dealer. After getting the run around I asked to talk to one of their "transmission" guys. Told him I just needed one check ball. HE said sure, come on it. I brought him a 6-pack for helping me out. Got some funny looks leaving the dealership....
http://www.ford-trucks.com/forums/92...-question.html
Old 09-20-2010, 05:05 AM
i have a feeling he didnt need the part numbers lol. I posted the diagram off ford installer support and it was there now its gone ill try agian!
Old 09-20-2010, 05:09 AM
Old 09-20-2010, 05:10 AM
right now i can clearly see the diagram, hopefully it stays up!
Old 09-20-2010, 02:53 PM
Stewart_H's Avatar
The FMC Dealership website doesn't allow hot linking or image links. You have to right click on the picture, save it to your hard drive, upload it to a website like Photobucket or Image Shack, then post the image here.
You can see it because it's saved in your cache. Once you leave FTE and shut your computer down, you won't be able to see it posted here either.
Stewart
Old 09-20-2010, 02:59 PM
Stewart_H's Avatar
Here ya go bro, I got your back.
Stewart
Old 09-20-2010, 05:24 PM
cbradford cbradford is offline
cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.cbradford has a spectacular reputation.
You da man Stewart!!!!!!!!!!!!
Reps to you bro.
Old 09-20-2010, 06:08 PM
Lol thanks man i lurke on the site more than i post but dont mind helpin a brotha out when in need! Now that i know what i need to do to post something of ford installer support i will thanks!
4r100 Check Ball Locations on Accumulator Plate danspears1 Clutch, Transmission, Differential, Axle & Transfer Case 2 09-19-2010 07:25 PM
Need help re: 01 X Calibration Plate danspears1 Excursion - King of SUVs 0 09-19-2010 02:47 PM
1989 F150 Orifice tube location Chad102 1987 - 1996 F150 & Larger F-Series Trucks 3 05-24-2010 08:50 AM
How much A/C oil mchild Cooling, Heating, Ventilation & A/C 2 07-05-2009 06:20 AM
AC not working ckb2steelers Explorer, Sport Trac, Mountaineer & Aviator 1 06-07-2004 08:06 PM
Tags
4r100, accumulator, ball, balls, body, check, ford, installer, location, locations, pictures, spring, support, truck, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
