bleeding clutch slave cylinder - Ford Truck Enthusiasts Forums
Old 09-18-2010, 05:13 PM
connor_warren59 connor_warren59 is offline
connor_warren59 is starting off with a positive reputation.
I'm having trouble bleeding my clutch slave cylinder, ive been working on it for the past four hours and have gotten nowhere. I started out using a vacuum bleeder at first and that wasn't working so then I had a buddy come help me and it still wasnt working. I was wondering if there is some trick I am missing because this is really starting to frustrate me. It's an '89 F-350 diesel.
Thanks
Connor
Old 09-18-2010, 06:25 PM
Zorfox Zorfox is offline
Zorfox is starting off with a positive reputation.
Did you fill the cylinder with fluid before installing it? If not you'll be there all day. Fill it, install, remove the cap and diaphragm (open the bleeder on concentric types) and let fluid run out until no air. Then you can bleed essentially like brakes. Sounds like you just forgot to fill the cylinder first.
Old 09-18-2010, 09:09 PM
well i dont know. i bought it on thursday and the guy said he installed a new slave and it just needed to be bled again so thats what i was trying to do. so what you're saying is that i'll have to remove the slave cylinder and fill it with fluid? do i just fill it where the hose from the master cylinder hooks up? I couldnt even really tell how to remove the slave, it wasnt being held on with bolts or anything that i could see. im fairly mechanically inclined but this is the first time ive every worked with a hydraulic clutch system so its essentially like talking to a five year old. basically the more you can dumb it down the better haha. thanks for the quick reply though, ill get back to it tomorrow when im fresh.
thanks again
connor
Old 09-18-2010, 11:47 PM
F150xlt F150xlt is offline
F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.F150xlt has a very good reputation on FTE.
Old 09-19-2010, 05:40 PM
hmmm...well i tried that and i lost pressure completely. i must not have been doing it right. I ended up just pumping the piston on the slave by hand which pushed most of the air up through the line and out the master. i was able to get pressure back so i can drive it but it still feels like it has some air in there somewhere.
Old 09-19-2010, 08:47 PM
John 300 John 300 is offline
John 300 is starting off with a positive reputation.
IVE BOUGHT BAD SLAVE CYLINDERS BEFORE AT ORIELLYS THIER ONLY $25 MIGHT TRY A DIFFENT ONE .IVE BEEN IN THE SAME BOAT YOU ARE SPENT DAYS LETTING IT SIT TRYING TO BLEED THEM I WENT AND GOT A DIFFERENT AND WAS ON THE ROAD IN 10 MIN
2x4 to 4x4 Connor O'Brien 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 12-31-2014 12:26 PM
Bleeding clutch 264WSM 1987 - 1996 F150 & Larger F-Series Trucks 4 06-29-2013 08:40 PM
How to bleed master/slave clutch cylinders 89nolaf250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 8 01-31-2010 02:37 PM
Bleeding the clutch slave cylinder mrbs66 1999 to 2016 Super Duty 4 11-21-2008 04:10 PM
slave cylinder bleeding elojsgonz Clutch, Transmission, Differential, Axle & Transfer Case 1 11-18-2005 01:08 PM
Tags
150, 1987, bleed, bleeding, clutch, cyl, cylinder, duty, f150, f250, ford, hydraulic, install, slave, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
