Door panel fasteners - Ford Truck Enthusiasts Forums
Old 09-18-2010, 03:08 PM
TGenolcyC66 TGenolcyC66 is offline
TGenolcyC66 is starting off with a positive reputation.
What door panel fasteners do I need for my 71 F100 Sport Custom? I have looked at LMC and NPD, and they don't list them. Any help is appreciated!
Old 09-18-2010, 04:34 PM
Phil105's Avatar
Phil105 Phil105 is offline
Phil105 is gaining momentum as a positive member of FTE.
Pretty sure Dennis Carpenter has them - and I'm surprised NPD doesn't.
Old 09-18-2010, 05:13 PM
Nope
Didn't find them at Carpenter either, they all list prior and post 1971, but no 1971. I guess I'll have to pop the passenger door panel, drivers door has none, the handles and arm rest are holding the door panel on!
Old 09-18-2010, 05:35 PM
Phil105's Avatar
Quote:
Check with a local upholstery shop
Old 09-19-2010, 04:35 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
The upholstered door trim panel is retained to the door by the separate door trim panel moulding which surrounds it.
The clips used to retain the moulding also retain the door trim panel and are the same for all 1967/72 F100/750's since the moulding (C7TZ8120942A) is the same.
This before and after 1971 jazz is BS
Pictured here: 1964/72 Ford Truck Parts Catalog / Illustration Section -Interior Trim - Page 17.
C7TZ81237A84B .. Door Trim Panel Moulding Retainer Clip / Obsolete
ANTIQUE AUTO SUPPLY in Arlington TX has ONE = 817-275-2381.
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
No Ford Dealer, no other obsolete parts vendor has any.
I looked in Carpenter's 1967/79 truck repro parts catalog, he does not have these clips. He has them for 1973/79's, but they are not the same.
The clips are not listed in Carolina Classics (carolinaclassics.com) or the Truck and Car Shop (truckandcarshop.com) repro parts catalogs. I don't have any other repro catalogs.
Ford used a 'scissors' like clip for decades to retain door trim panels on passenger cars. It's possible one of these types could be substituted.
Upholstery shops carry these, but take the moulding with you as there are different widths.
Old 09-19-2010, 07:36 AM
Good info Bill, thanks! My local Napa guy said he has a bin full of clips, but I need to know what I'm looking for. The passenger door is tight, need to work on the door lock anyway, will pull it and see if I can match them up.
Old 09-20-2010, 02:37 PM
xlt70black xlt70black is offline
xlt70black is starting off with a positive reputation.
Door panel clips
Try the mustang repro. guys it's been a few years since ive been in the doors of my 69' stang but if memory treats me right the mustangs with the base model door panels used the same retainers as the the trucks used if they had the vinyl type panels seams like the 71'72's ford did away with the metal door panel and went with the full vinyl type panels your panel should have a ''D'' type hole that the clip will slide into and the part of the clip thats going to fit into the hole on the door will be the scissor type be very careful pulling that passenger panel off that door panel is OLD and the material its made of is going to be brittle they make a tool looks like a fork it's for sneaking behind the panel and prying directly on the clip and less on the panel good luck
Old 09-20-2010, 06:31 PM
Quote:
Originally Posted by xlt70black View Post
Try the mustang repro. guys it's been a few years since ive been in the doors of my 69' stang but...
if memory treats me right the mustangs with the base model door panels used the same retainers as the the trucks used if they had the vinyl type panels.
Seems like the 71'72's ford did away with the metal door panel and went with the full vinyl type panels your panel should have a ''D'' type hole that the clip will slide into and the part of the clip thats going to fit into the hole on the door will be the scissor type be very careful pulling that passenger panel off that door panel is OLD and the material its made of is going to be brittle they make a tool looks like a fork it's for sneaking behind the panel and prying directly on the clip and less on the panel good luck
C7TZ81237A84B is the part number for 1967/72 F100/350. This part number is not listed in the car parts catalogs.
The trucks have a separate moulding surrounding the door trim panel, the clips that retain the moulding also retain the door trim panel.
The same moulding was used 1967/72. The clips that retain the moulding/trim panels are the butterfly type, not the scissors type.
I suggested the OP try scissors clips since only two of the correct clips could be found.
Mustangs do not have a separate moulding, the clips are the scissors type: 383033S
1967/71 F100/350 Customs have metal door panels, Rangers, Ranger XLT's have upholstered door trim panels.
All 1972 F100/350's have door trim panels, including Customs.
Old 09-21-2010, 05:41 AM
Retainer
The trim number dude is talking about was used up till 70' the 71'-72' sport custom / explorer / ranger / ranger xlt ford went to a full upholstered panel that did not use the stainless with black stripe trim on these panels the trim did not hold the panel on the door it just covered the screws you have to take the trim off then you can get to the screws that hold the steel panel on once you remove the window crank and door release and arm rest you can then remove the steel panel the steel panels have holes just big enough to retain the stainless trim with the butterfly clips the door will have a hole in the same area of the hole in the panel about an 1/8'' larger so the trim clips only bite on the panel not the door so you can remove the panel the 67'-70' with upholstered or molded plastic panels are smaller and afix to the steel panel then they put the stainless trim on to hide the screws and make a good looking panel if you go to cjponyparts.com and put HW 420 in the search box I bet those clips will work
Old 09-21-2010, 09:50 PM
RichS2659 RichS2659 is offline
RichS2659 is starting off with a positive reputation.
[quote=NumberDummy;
All 1972 F100/350's have door trim panels, including Customs.[/quote]
Bill,
Please revise your data as my dad's specially ordered 72 F-100 Custom which we received in March, 72 had white metal door panels held on by philips head screws.
Old 09-22-2010, 06:32 AM
I'm not revising my data based on a special ordered truck, because the 1964/72 Ford Truck Parts Catalog lists door trim panels for all 1972 models.
If the truck was a special order, and your dad specifically didn't want door trim panels, Ford would have deleted them.
A special ordered vehicle like this would have 6 digit DSO denoting a Domestic Special Order.
Old 09-23-2010, 12:45 AM
Bill,
Dad only ordered a base truck from the dealer with only 6 options. That is what Ford shipped us for the trim level, a White interior with the metal door panels in a Coral Custom. They must have been clearing out the warehouse stock since the wouldn't be used in the new 73's. The air filter housing was an oddball as it took Fram CA-351 filters (crossed to D2AE-9601-AA according to Fram) instead of a CA-324 (C8AF-9601-A) as listed in the catalogs. I remember the CA-351 as it was listed as being used a Ranger filter, but I didn't have a Ranger trim level. The options were 302, long bed, T-18, AM radio, the best bench seat that we could get for the Custom base trim, and a step bumper. We got a stupid little mirror in the glove box which dad threw away, and put on a set of aftermarket West Coast mirrors which we threw away 5 years later, when we bought aftermarket copies of the 77 swing mirrors which were very nice, and not door crushers in brush.
Old 09-24-2010, 05:09 AM
Quote:
Originally Posted by RichS2659 View Post
Bill,
I dunno what catalog you are refering to...the following is from the 1964/72 Ford Truck Parts Catalog.
C8AZ9601A .. Air Cleaner Element (Motorcraft FA50)
1968/72 F100/350 360/390 / 1969/71 F100 302.
D2AZ9601A .. Air Cleaner Element (Motorcraft FA97)
1972 F100 302.
Both these elements were also used on myriad Passenger Cars.
Whether the truck is a Ranger...or not, has nothing to do with what air cleaner it has. Oil bath air cleaners were available as an option.
1967/72 F100/350: The standard equipment left hand outside mirror was the el cheapo manually operated passenger car type (C7AZ17696A).
This mirror was not installed at the factory. All outside mirrors were installed by the dealers.
If this mirror (or any other style of outside mirror) was factory installed, and the customer wanted something else, the holes in the door(s) would have to filled in and then the door(s) would have to be repainted.
65 interior door panel question 65rat 1961 - 1966 F-100 & Larger F-Series Trucks 4 04-07-2014 10:29 PM
need help finding a good way to fasten door panels Björn 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 07-21-2013 03:46 PM
Door panel fasteners jmcgee 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 33 10-14-2012 08:24 PM
Removing Door Panel? Nitramjr Escape & Escape Hybrid 2 09-27-2010 07:49 PM
I need the part number for door panel fasteners rob-o 1987 - 1996 F150 & Larger F-Series Trucks 5 01-11-2010 10:19 PM
Tags
1971, 2003, car, clips, custom, door, escape, f100, fasters, ford, panel, parts, plastic, tool, trim, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
