How to remove driver's side front fender on '92 F150?
on
Open the hood and prop it up with a stick against the rad support on the pasenger side. First remove everything attached to the inner fender, and then remove the grill and the washer fluid resovoir so you can access all the screws that hold the headlight assembly in, some are behind the grill and some are behind the rad support. Remove the headlight and then remove the bolts connecting the trim piece above the bumper to the fender. Then remove all the screws around the wheel opening attaching the plastic splash guard to the fender. Then open the door and remove the bolt between the two hinges and the one at the base of the fender near the door seam. Finally there are bolts at the rad support and at the top rear of the fender by the hinge, once they are out the fender should be loose.
SuperDuty93
20
03-29-2016 05:27 PM
91CavGT
01-02-2014 01:37 PM
vintshave
06-27-2013 06:48 AM
Elmo154
04-18-2009 08:08 PM
