Recommended Rebuild Kits?
I've got this motor down to the block, and it's going in for honing, magnaflux, and boil this week. I'm going to be rebuilding the bottom end, replacing one head, and rebuilding another. Any recommendations on where to source rebuild kits? Any links would be appreciated. Thanks!
Let your machine shop buy the rebuild kit...nothing worse then customer supplying pistons and bearings that are .010 over when the cylinders dont clean until .013. Plus most shops get kits like that for cheaper then you can by buying straight from the dealer. Also I'd reccomend making sure the shop checks the main bores for trueness and cleans up the deck.
Side tip if you dont already know the factory main, rod and head bolts are Torque to yield which means you should replace with new ones
As far as cams nobody makes aftermarket but if the lobes are pitted send them to crower and they will check them for straightness and true them up and do a regrind for about 10 duration and send them back clean for about $300...
93PGT
07-17-2010 11:48 PM
CharlesFrankenstein
15
10-13-2009 07:34 PM
