Help To Decode E10 Tag - Ford Truck Enthusiasts Forums
Old 09-16-2010, 10:26 PM
Baltons Baltons is offline
Baltons is starting off with a positive reputation.
I have just purchased an E10 & need some help with the tag numbers
Tag Reads
E10JH703204
J90 F E100 287 A 17
3600 129 4000 71
Cheers
Old 09-18-2010, 12:12 AM
66gpw's Avatar
66gpw 66gpw is offline
66gpw has a good reputation on FTE.66gpw has a good reputation on FTE.
E10 is a van pick up
J is for a 240 6cyl eng.
H is the Lorain assembly plant
703204 is the truck was built in June of 1965.
J90 is the wheelbase.
F is a color. Lt Blue
E100 Regular Pick up model
287 Standard pick body style
A is C4 auto Trans.
17 is suspose to be an axle code. My book does not show a 17 for 65.
The last is the GVWR max weight is 3600lbs
The next feww numbers I do not know. The 71 is the destination of the truck after assembly was Los Angeles.
Old 09-20-2010, 08:59 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
A is C4 auto Trans.
The next few numbers I do not know. net HP @ RPM
E10 = Econoline Pickup.
287: 2 = Medium Blue Crush Vinyl & Medium Blue Stitch Pattern Vinyl // 87 = Econoline Pickup.
A = Ford type 3.03 3 Speed Manual all Syncromesh Transmission.
17 = ??
3,600 lbs. Gross Vehicle Weight Rating.
129 net HP @ 4,000 RPM
71 = Los Angeles CA Ford District Sales Office, where the original selling dealer ordered the Econoline from, but this does not necessarily mean the Econoline was shipped to LA, because...
FoMoCo dealers in Hawaii ordered their vehicles from Los Angeles, so the Econoline could have been shipped to one of the Hawaiian Islands.
The OP is located in Australia, so it's possible that the Econoline could have been shipped there.
If a C4, the TRANS code would be G ... but, Ford used G for all A/T's thru 1978.
One had to know which A/T came with what engine.
1997 E350 V10 door jamb tag help requested! Monster Van Mike 1968-2013 Full Size Vans 7 11-09-2012 10:47 AM
Door jamb tag decoder help please! Monster Van Mike 1999 to 2016 Super Duty 6 11-01-2012 10:06 AM
need help IDing 9inch low54 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 07-01-2009 03:15 PM
Rearend ID tag question mikeberman04 1978 - 1996 Big Bronco 2 04-26-2008 08:08 PM
Can a transfer case tag be decoded? klassik1 Clutch, Transmission, Differential, Axle & Transfer Case 1 01-24-2005 07:25 PM
Tags
1967, au, decoder, e10, econoline, f150, ford, fuel, parts, tag, truck, type, van, vin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
