speedo gear
speedo gear
i checked with my local Ford dealer. they were absolutely useless. they said that all the gears were color coded, and that they did not know how many teeth each color had.they also said they had no way of knowing which gear i would need. snce the car i am working on never came with 4.10 gears. or any formula to find out which gear i needed. i know there is a formula. i used it on another vehicle. i just cat find it online anywhere.
thanks
matt
thanks
matt
speedo gear
The formula you want is:
Driven gear teeth = (Drive gear teeth x axle ratio x tire revs/mile)/1000
In your case that's:
driven gear teeth = (7 x 4.11 x tire revs/mile) / 1000.
or T = .02877 x tire revs/mile
You cannot accurately calculate tire revs/mile from diameter. You need to look it up for your tires either on the manufacturer's site or at www.tirerack.com
Don Vito
11-29-2016 08:44 AM
blk450er
09-13-2016 06:39 PM
hest_c
06-27-2016 10:43 AM
cleanLX
03-22-2005 10:34 PM
