1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
08 6.4 DPF needs replaced per dealer
Old 09-16-2010, 01:11 PM
dcoll's Avatar
dcoll
dcoll is offline
Angry 08 6.4 DPF needs replaced per dealer
At 115,000 had to replace turbo $5,000 after dealer and Ford contributed. Now at 117,000 miles DPF needs replacing per dealer @ $2,200 plus tax. Regen without dash stating so. Excessive blue smoke when regen and will do under 30 MPH. Dealer says I need new DPF. My questions to all is:
How long do DPF last?
Can clean DPF anyway?
DPF delete who in Baltimore would do this?
Is the DPF delete the way to go?
How much should I pay to do this?
Old 09-16-2010, 01:49 PM
i eat hybrids's Avatar
i eat hybrids
i eat hybrids is offline
If your outta warrenty, i would deff not put that DPF back on.. Its a waste. You could get almost three turbo back exhausts for the price of one DPF. Also, if i were you, i wouldnt go back to that dealer.
Old 09-16-2010, 02:11 PM
dcoll's Avatar
dcoll
dcoll is offline
Now the service manager just returned our call. He has informed us that he wants someone else to look at it to get a second opinion. We will see. Pretty crazy to first tell me that I need a $2,200 part and then now wants someone else to look at it. The company that I work for buys a lot of cars from this dealer. I will keep everyone posted. Thank you.
Old 09-16-2010, 02:49 PM
senix's Avatar
senix
senix is online now
Received 1,400 Likes on 997 Posts
who is your dealer? Sounds like it is time for another...what codes are they getting if any.
Old 09-16-2010, 03:22 PM
ExplorHer1369's Avatar
ExplorHer1369
ExplorHer1369 is offline
I thought DPF delete was the way to go.
Old 09-16-2010, 05:06 PM
bpounds's Avatar
bpounds
bpounds is offline
Kind of depends on where you live, and how comfortable you are with committing a crime.
Old 09-16-2010, 05:08 PM
smlford's Avatar
smlford
smlford is offline
Don't know for sure but isn't the DPF part of the emmissions system? If so it sould have a longer warranty.
Old 09-16-2010, 05:15 PM
bpounds's Avatar
bpounds
bpounds is offline
Yes it is, but warranty is 5yr/100k.
ruschejj's Avatar
ruschejj
ruschejj is offline
I put 153,700 miles on a 6.4 and never had any DPF issues. I don't think Ford or hardly anyone else really knows the life expectancy of those things. It will become more common to see issues once the 6.4 starts seeing service beyond 150K miles and a few years. In this sense, everyone with a diesel that has a DPF is really a test driver. You may be very early in the data collection pool in this regard.
Old 09-16-2010, 05:19 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
this sounds very much like another user DPF problem, where the turbo seals are leaking, letting too much oil into the exhaust, clogging the DPF... not the DPF's fault..
https://www.ford-trucks.com/forums/9...ml#post9324981
sam
Old 09-16-2010, 05:33 PM
PowerStrokeHD's Avatar
PowerStrokeHD
PowerStrokeHD is offline
DPF maintenance and longevity will vary depending on the particular operating conditions of the vehicle. Ford estimates cleaning of the DPF at approximately 150,000 mi (right in line with the EPA requirement) and replacement at approximately 250,000 mi. It looks like you did good with yours...
Old 09-16-2010, 05:38 PM
bpounds's Avatar
bpounds
bpounds is offline
I don't understand how that is a user problem.
Old 09-16-2010, 06:35 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
| ah, I see it.. my comment was "this sounds very much like the problem ANOTHER USER was experiencing "
Sam
Old 09-16-2010, 06:45 PM
bpounds's Avatar
bpounds
bpounds is offline
Now I get it. Sorry, my mistake.
Old 10-12-2010, 10:13 AM
dcoll's Avatar
dcoll
dcoll is offline
an answer to the mess
Apparently when my turbo went up it leaked oil into the DPF. It will take time to burn off during the regen process. It is going thru the regen process without the dash message coming on. Mechanic informed me that was impossible. He kept truck for 4 days taking it home with a scanner attached to the vehicle. It did go thru regen without message on dash. He ws wrong. He had never seen that.
So bottom line is that i am dealing with the regen coming on without notification and more blue smoke than normal unti all is burned off. No need for new DPF.
Thanks to everyone who responded.
Quick Reply: 08 6.4 DPF needs replaced per dealer
