Switch from a D50 to a D60?
I need new front axle shafts in my truck and the best way to get them is by just getting the whole axle out of a parts truck.
I have one of the 99-01 trucks with a solid dana 50 front end.
If I get the axle out of an 02+ truck, will the whole thing just bolt right up giving me a Dana 60?
I would assume so as the F-350 duallys got a Dana 60 in 02, but the real question Bill, is why? The axles are rated at exactly the same FGAWR for the 99-04 series, dependent of course, on the spring rates. (Max was 5200) If you are not running a plow or some other type of heavy equipment on the front, it won't matter.
Yes, based on these Ford specs.
2000 - Page 52
https://www.fleet.ford.com/truckbbas...0/BBFSD00A.PDF
2001 - Page 53
https://www.fleet.ford.com/truckbbas...1/fsersdcd.pdf
2002 - Page 59
https://www.fleet.ford.com/truckbbas...2/fsersdcd.pdf
2003 - Page 55
https://www.fleet.ford.com/truckbbas...essd_03abb.pdf
2004 - Page 55
https://www.fleet.ford.com/truckbbas...essd_04abb.pdf
2000 - Page 52
2001 - Page 53
2002 - Page 59
2003 - Page 55
2004 - Page 55
I suspect Wiki is a little sketchy on the years and info.
http://en.wikipedia.org/wiki/Dana_60
http://en.wikipedia.org/wiki/Dana_50
Yes, its a 2001 SRW F350.
I am planning on off roading and tractor pulling with it, and I am just worried about breaking it.
It already needs to be changed from the PO tearing it up, so this would be the perfect time to upgrade.
So the SRW trucks started getting the Dana 60 in 2004?
I would relay more on the users opinions, than on factory specifications.
My Dana 80 blow up for no clear reason. I was driving with no load, on almost flat highway and moderate speed. The bearing cage come apart and messed up everything, but the bearing parts didn't show any wear out, so I am still puzzled how that could happen. The bearings were Japanese. I replaced with Timken.
Brown Falcon
08-09-2011 04:41 PM
Jayme Duty
11-11-2010 02:02 PM
Waxy
1999 to 2016 Super Duty
10-18-2010 11:32 PM
