How to replace a pinion bearing? - Ford Truck Enthusiasts Forums
Old 09-15-2010, 10:22 PM
79 bronc's Avatar
79 bronc 79 bronc is offline
79 bronc is starting off with a positive reputation.
Hi all,
I need to replace a pinion bearing and seal on a 98 F250 with a 10.25 axle. I read up on this topic but still have a question.
When I re-install the pinion with a new crush washer, is it ok to just use the origingal shims? Or do I need to go through the whole process of aligning the ring and pinion with re shiming if needed?
thanks,
Old 09-18-2010, 11:29 AM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
I've always just reused the shims that were there when replacing bearings.
Old 09-18-2010, 02:05 PM
zooom zooom is offline
zooom is starting off with a positive reputation.
The cost of replacing the shim(s) is relatively small compared to a complete axle re-do if you reuse the old shim(s) & they disintegrate when you torque down the pinion nut to get the necessary preload.
Save yourself a headache & use new shims....
Old 09-18-2010, 02:54 PM
bashby's Avatar
There is no pressure put on the shim when torquing the pinion nut, how could it desintegrate?
How to replace your differential pinion seal with no special tools (tech folder?) EXv10 Excursion - King of SUVs 0 12-23-2014 09:37 PM
8.8 pinion bearing replacement konasexone 1997 - 2003 F150 3 12-23-2009 02:56 PM
Need advice on pinion seal replacement jade79 Ranger & B-Series 2 11-01-2009 10:25 PM
9 inch pinion bearing replacement fordmaniac21 Clutch, Transmission, Differential, Axle & Transfer Case 4 05-17-2003 10:38 PM
rear axle pinion nut torque fordmaniac21 Ranger & B-Series 3 03-22-2002 10:37 PM
Tags
150, 1994, 2000, 2007, bearing, changing, explorer, f150, f250, ford, pinion, pinon, replace, replacement, replacing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
