crown vic ifs in 56 f1
#31
I bought all the parts I needd to do the job. I have read all those posts several times, and like was said nobody has done a write up. so maybe I can start. Already took a bunch of pictures of the tear down. Thepitshop kind of scared me saying the older clip with the cv wheels only gave 1-2"? wow, maybe the wheels are the older ones? it seems like the newer cv's I saw today all had a flatter looking wheel (less off set). well if it doesnt work i'll have to redo everyting...thats if nice wheels that would possibly work won't be available for some reason.
#32
Here is a 95' model P71 Crown Vic Front clip with an 02' Lightning motor with 3K mounted up.
Here is the clip
Firewall work
Frame
Sitting in Frame
I do believe the 57 and up frame is a tad wider. So comparing what works well between 57-up and 53-56 may not be a apples to apples comparison.
Here is the clip
Firewall work
Frame
Sitting in Frame
MORE INSTALL PICS of the pre 03' steering box versus rack version
Below my Friend who did my IFS, Rear end, and MOTOR-Tranny-wiring-AC-Intermittent Wipers. In short guy who got me rollin' working on his next 56'
#33
If you bound and determined that you can just slice and dice, swap and substitute on an IFS and it will drive properly and be safe on the road then anything anyone says here is not going to change your mind. Please do me a favor tho and let me know where you will be driving this so I can be sure to stay far far away. The relationships between all the parts (the geometry) is the difference between a drivable vehicle and an accident going to happen. The problem is the innocent(s) you may take with you.
#34
drivability is not an issue with this clip, its the width and only the width, that is the only issue with this clip (unless the installer doesnt know how to read a tapemeasure). i have been driving mine for 3 months everyday including a drive from houston to dallas and back with absolutely no issues. ...is something i wouldnt be doing with a unsafe truck.
#36
Please don't misunderstand my comment. As designed, I'm sure there is no drivabilty issues with this IFS. There is as you say a width problem with using it as is in a pre 57 truck, the tires will not clear the fenders unless the front end is lifted. I was commenting on the original poster's wanting to "solve" that issue by either/and 1. narrowing the CV crossmember, 2. using custom reverse offset wheels, 3. shortening the A-arms. Any/all of these mods would drastically change the steering geometry, and if done by someone who doesn't understand the ramifications of such mods result in something that could be unsafe to totally undrivable. THAT was what I was concerned about ending up on the highway.
Anyway the wheels I am buying are 19" with a 42mm offset. this gives alittle over 3"out and you have the hub surface wich comes out 16". total of 19.5", I think this will fit inside the fender. I measured the truck, cv, new wheels, all just about clear but very tight.
Monday I will do my final measurments with the cv fornt end and the wheels next to the truck. Thats when I will make my final descision.
#37
#38
Sorry if I misunderstood on the wheels. I was under the (mis?) understandinding that (some of?) the stock CV wheels were already positive (reverse in my way of thinking moving the tire towards the center of the vehicle) offset? (offset is the difference between the wheel mounting surface and the center of the rim. see Wheel Tech - Offset )
If the wheels you are ordering have more positive offset than stock to try to make the track width narrower, that will affect the geometry adversely.
Not only do you need to have ~1" clearance between the tire and fender (and the tire and frame/suspension) when the wheel is pointed straight ahead to allow for suspension movement, but also when the wheels are fully turned.
I am not an engineer, but I do have a LOT of knowlege of suspension and steering from my research and hands on experience with racing suspensions, both drag racing and autocross.
#39
#40
IMO, I would first use the original wheels from the CV to see where they lie under the fender lip. And determined on that, you can buy an aftermarket wheel to match, or go to plan B. If the stock wheel seems ok, then the designed geometry should be pretty good. Not perfect though, since the rear may not be of equal height as a stock CV, which puts the A arms at a different angle than the stock CV, which obviously changes caster. Either way, you'll get the feel of how it handles by driving around the block with stock wheels first.
#41
I think i'm starting to lean towards the jag set up. I just dont think there will be enough clearance for the exhuast of the 5.4, or maybe steering isues. also all the braking stuff, wheel lug pattern. besides i've read just about all posts about the jag ifs and none are 100% complete.
#42
There are a number of completed Jag swaps, especially among our down under Ausie brothers where it is more popular than the MII type. Holmsey has done a multipart writeup on his finished swap. The Jag is a near perfect choice, the car has the same tread width, near same frame width (a minor trimming needed to fit the 53-56 frame, bolts right in to the 49-52) the front end weight is nearly the same, so the OEM springs, sways and shocks work, and it's an excellent design. It will drop your front end a couple inches or more depending on if you use the viscous vibration damper mounts or not. The Z joint in the steering is a little bulky but needed with the damper mounts, but any clearance issues can be solved by offseting the engine 2" to the right. If you buy a whole car for the donor, the IRS can also be installed with just a bit more effort and your truck will then corner like a sports car and ride like a ...well.. Jag sedan!
#43
#44
If the oil pan sump on the mod motor will clear any IFS crossmember it would clear the Jag crossmember. The problem with IFS swaps with a non mod motor FoMoCo small block is that most have a front sump oil pan interference problem. The solution for the non mod 302's is to go to a Bronco style mid sump pan and pump. I don't know what type oil pan the mod motor has or if you could use the Bronco pan. Ford has recently increased their interest in hot rodders using the mod motor so they have put a number of parts into their performance parts catalog, wiring harnesses etc. It looks like the install in Tacson's pictures moved the engine back to clear the sump but that means intruding into the cab and being limited to using an auto tranny, a manual tranny shifter would be too far rearwards.
