Camper Package on new 2011
From the 2011 order guide:
http://www.profleetsales.com/pdf_fil...er%20Guide.pdf
CAMPER PACKAGE (471)
Availability:
Optional on all Pickups
Not available with:
20" Wheels and Tires, Pickup Box Delete (66D), 3.31 Axle Ratio
(on 4x4 with 17" or 18" tires) or Heavy Service Front Suspension
Package (67H)
Package (67H)
Includes:
Extra heavy service front springs (4x2) (2 up upgrade above the
spring computer selected as a consequence of options chosen. Not
incl. if maximum springs have been computer selected as standard
equipment)
equipment)
Heavy service front springs (4x4) (1 up upgrade above the spring
computer selected as a consequence of options chosen. Not incl. if
equipment)
equipment)
Rear stabilizer bar (SRW only)
Slide-in camper certification
Rear auxiliary springs (F-250 only)
NOTE: Salesperson's Source Book or Ford RV Trailer Towing
Guide should be consulted for specific trailer towing or
camper limits and corresponding req. equipment, axle
ratios and model availabilityGuide should be consulted for specific trailer towing or
This package is designed around slide-in truck campers NOT tow-behind campers. Not necessary in your application.
I have it on my new '11 F350. I do have a slide in camper that weighs around 1500lbs, and also use the truck for towing a travel trailer.
I like the stiffer springs, I don't like the rear sway bar, hurts off road performance, and my relatively light slide in camper doesn't need it.
So, I will be yanking off the sway bar.
The odd thing is this time no camper certification sticker (listing max weights in bed and distribution) appears in my glove compartment, which is different than previous super duties.
On extreme off road maneuvers, a sway bar can prevent full suspension articulation, preventing a wheel from drooping down the full travel of the suspension and contacting the ground.
95% of Super Duty owners would not get in a position where we needed this articulation to get our truck going because we would not drive our trucks into this situation in the first place.
But, I wood cut, and have a buddy that lives up a nasty barely 4wd drive that I need to get into multiple time a year, so off it comes. I yanked the front swaybar off my mountain snowmobile, it has done wonders for my ability to pitch the sled over....
Thanks, that's what I was thinking, but wanted some verification as whether this option would be beneficial for any other use besides a slide in camper since the option is not very expensive. I will eliminate this option from my wish list.
'08 F250 CC 4WD...
Purchased new, no camper certification sticker that I could find, but an 8" x 11" paper certification was in my glovebox. It was also noted on the window sticker, and was an inexpensive option if I remember correctly (around $145.00 or so). A rear sway bar, HD front springs and "helper" rear springs for $145.00 - when a pair of tow mirrors were quoted at over $1600.00!!
I made a copy for the glovebox and yanked the original to keep with the window sticker.
