Engine builders, machine shops in / near RI? - Ford Truck Enthusiasts Forums
Rhode Island Chapter Join Chapter, Leader: dynamic
Old 09-15-2010, 07:55 AM
lasitter lasitter is offline
lasitter is starting off with a positive reputation.
I have a 4.9L inline six, and it seems to be running fine now, but I haven't even bothered with a compression test yet. So ...
If I ever developed a problem / needed some work done, I'd be interested in identifying vendor(s) with:
- Good rep. for engine work generally
- Experience building this engine would be a plus
- Reasonable (non-dealer!) rates
- Reasonable driving distance from Pawtucket
No objection to paying a group member / someone with a home shop, if the other qualifications were satisfied.
Old 09-15-2010, 01:44 PM
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
Everyone I know seems to love Simplex Engines. They're in providence and they'll do anything from big diesels to lawnmower engines.
Simplex Engine & Machine
Old 09-15-2010, 02:07 PM
Quote:
Originally Posted by Lead Head View Post
Thanks. I'll check them out.
Old 09-17-2010, 04:06 PM
Bob Gervais's Avatar
Bob Gervais Bob Gervais is offline
Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.Bob Gervais has a great reputation on FTE.
I've used Simplex in the past with excellent results also.
Gear Vendor swap from C6 (2WD) to NP205 (4X4, divorced transfer case) karljay 1973 - 1979 F-100 & Larger F-Series Trucks 17 11-24-2015 07:49 AM
1995 Ford F150, 5.0L, 4WD, Dana 44 TTB, Complete Rebuild Vendors OFLM 1987 - 1996 F150 & Larger F-Series Trucks 2 02-16-2015 08:28 AM
fuel filler hose shopping triskadek 1978 - 1996 Big Bronco 3 03-16-2014 07:44 AM
Remanufactured 360 Engine Vendors? jax72sportcustom 1967 - 1972 F-100 & Larger F-Series Trucks 6 09-11-2012 05:21 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
30, 49, bob, builders, engine, ford, gervais, island, machine, motor, providence, race, rhode, ri, sho, shop, shops, westerly
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
