Launch Off The Line
Old 09-15-2010, 01:11 PM
djjoshuad's Avatar
djjoshuad
djjoshuad is offline
Originally Posted by rickatic
that's what us boys up north here call brake torque...
silly northerners, eh?
Old 09-15-2010, 01:27 PM
rickatic's Avatar
rickatic
rickatic is offline
not that far north...no eh's here in southeast Michigan...except in da UP eh der den...
Old 09-15-2010, 01:43 PM
dylan8427's Avatar
dylan8427
dylan8427 is offline
Originally Posted by Ford_Six
I've fought this with a few different electronic throttle vehicles. Regular EFI vehicles with a throttle cable don't have this problem, so i seriously doubt the computer in these newer vehicles has trouble keeping up.
While they aren't as bad, I still see a throttle lag compared to a carbureted gas or mechanical diesel.
The computer does have to calculate how much "throttle" to give when you move the accelerator, but that's a pretty quick calculation. The delay on mashing the pedal is mostly to prevent an accidental acceleration, if you hit it hard and then release, it just stays at idle.
That's a good point, that may be most of it! I still say it needs the time to gather info from all the various sensors before it dumps fuel in - for emissions reasons, as opposed to 'blindly' dumping in fuel though. lol
Old 09-15-2010, 07:15 PM
FORDTUF1's Avatar
FORDTUF1
FORDTUF1 is offline
How far up North or you?
I'm from Illinois and we called it power braking, still do in the South.
Okay just saw farther down in the thread, Michigander.
Old 09-15-2010, 09:58 PM
rickatic's Avatar
rickatic
rickatic is offline
Power braking is what us boys up here in the motor capital of the world call a truck with vacuum or hydro-boost brakes. Hole shots are accomplished with brake torquing. You see you are holding the brake and torquing up...oh never mind, you get it.
Old 09-15-2010, 10:11 PM
cummins cowboy's Avatar
cummins cowboy
cummins cowboy is offline
its normal my dodge does the same thing, I am running a smarty tune, which helps out a ton, it can be somewhat scary jumping out into traffic. say if you are left turning and need to get it done quick the stock program has quite a big of hesitation to it, the smarty helps a lot but in that situation it puts out a ton of smoke before it spools but all that smoke helps it spool faster, really romping on it like that with the smarty tune will break the tires loose and maybe get you sideways if you are an idiot driver.
Old 09-17-2010, 02:37 PM
cowmilker08's Avatar
cowmilker08
cowmilker08 is offline
Plus when the oncoming traffic sees the smoke they might slow down and give more time to get through the intersection, lol.
All I was saying about the brain thing is that your body takes in info slower than a computer, but your brain can predict would is going to happen better than a computer so with practice you can perform faster than you can take in what your doing.
350Rancher
6.7L Power Stroke Diesel
19
07-10-2012 08:33 PM
Ian123
06-22-2011 10:24 PM
ranger_ron
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
02-23-2006 07:30 PM
CentralCoaster
2004 - 2008 F150
51
10-27-2005 03:14 PM
woodman209
08-19-2004 10:23 PM
Quick Reply: Launch Off The Line
