MY 85 FORD F250 REBUILD (check this out its gona be SWEET!)
hello new here! Ive been rebuilding my fathers 1985 ford pickup! Im putting in 7.3 idi diesel out a 1989 f250.Im also putting the dash out the 89.I put a banks sidewinder kit on with the c-6 transmission Im replaceing 410 gears and putting 355 gears .So far i got the motor rebuilt and the truck all tore apart.Im using the dakota digital gauge cluster .So ill post picks I hope you like whats done so far .You all have a great
Looks good. Did you go through the entire motor? Did you have to bore it out or just hone the cylinders? Does that instrument cluster fit right in the factory spot?
I just put new gaskets, new glowplugs, injectors, Headstuds in everything else looked good. And yes guage cluster should fit directly into factory spot ,thanks for your interest
