F 350 brake problems - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-13-2010, 10:40 PM
wyavp wyavp is offline
wyavp is starting off with a positive reputation.
Hello I have a 1996 F 350 Power stroke 7.3 XLT centurion 2 wheel drive crew cab dually with cruise control. When I got the truck it had a very soft brake pedal that would almost bottom out even after pumping a few times. I have since replaced calipers, pads, wheel cylinders, shoes, left rear emergency cable, booster & master cylinder. After bleeding the old fashioned way with two people throughly the pedal still acts the same even though I can hear and feel the calipers and rear brakes grabbing.Is it possible the ABS cylinder could be bad as well and or does the bakes have to be bled while attached to a scanner to make them function properly? Or is it possibly a simple vaccum problem? Even though all seems ok with the vaccum lines.
90 f350 brake pedal fade bodmec Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 03-06-2014 08:27 AM
2003 F-150 brake issues cullscott 1997 - 2003 F150 3 07-20-2012 06:56 PM
Power brake pedal does not rebound jlp66stang 1973 - 1979 F-100 & Larger F-Series Trucks 7 12-04-2010 03:09 PM
Brake to Soft - 1992 F-350 C.C. 4X4 6Fastback7 1987 - 1996 F150 & Larger F-Series Trucks 6 04-22-2008 12:56 PM
brake problems Voodoo66 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 06-27-2006 11:52 PM
Tags
2004, 350, barkes, brake, diesel, f350, f350brake, ford, grabbing, problem, problems, rear, series, troubles, vans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
