Radiator drain valve - Ford Truck Enthusiasts Forums
Aerostar Ford Aerostar
Old 09-13-2010, 07:49 PM
Bax2008's Avatar
Bax2008 Bax2008 is offline
Bax2008 is starting off with a positive reputation.
Question Radiator drain valve
Having some issues with mine.
I apparently over-tightened it one year and it came out in my hand.
The only thing holding that in the rad is plastic tabs??
Bought and installed a new one, as the old one had bent tabs.
Now having issues with the new one. I noticed the valve was weeping, so I tightened it a quarter turn or so.
The &^$&^%#$^%!! thing blew off in my hand showering me up the to the elbow with hot antifreeze.
Now stop laughing and tell me how to fix it. LOL
I put it back in, but now I don't trust it to not blow off on the road.
Any suggestions?
Old 09-14-2010, 12:41 AM
96_4wdr's Avatar
96_4wdr 96_4wdr is offline
96_4wdr is gaining momentum as a positive member of FTE.
put a bead of this around the head shoulder of plug and tighten in snug but no wrench. finger tight only
let set overnight and fill
Permatex® High-Temp Red RTV Silicone Gasket
http://www.permatex.com/products/Aut...one_Gasket.htm
in Canada temps, you could run a lower pressure radiator cap also unless you tow.
Old 09-19-2010, 09:05 PM
a2racer86 a2racer86 is offline
a2racer86 is starting off with a positive reputation.
Sounds like you might have cracked the radiator where it goes screws in. I'd say a new radiator is the only fix I'd trust further that short trips to town and I'd probably have a couple gallons of water and another plug handy.
Old 09-21-2010, 04:22 AM
Pablo-UA Pablo-UA is offline
Pablo-UA is gaining momentum as a positive member of FTE.
exessive force of other mechanics lets me get some extra $$$ for additional repare LOL)))
Check your 18" wheel center caps! rdenis 6.7L Power Stroke Diesel 15 10-08-2014 01:06 PM
Scored a recall kit for dual fuel tank crossflow issue joegeds 1987 - 1996 F150 & Larger F-Series Trucks 13 09-29-2013 08:40 AM
Whats the Trick??? Banjo Fuel Feed Bolts ol-blu 6.0L Power Stroke Diesel 8 06-08-2012 02:27 PM
05 side mirror gpeade Expedition & Navigator 4 02-02-2012 12:17 PM
Fuel Filter replacement chunt 1994.5 - 1997 7.3L Power Stroke Diesel 8 10-07-2011 01:23 PM
Tags
1987, 2007, bronco, drain, draining, excursion, f150, ford, image, radiator, raidator, relief, truck, v10, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
