2 things: dp lope if you want to hear/ abs light beef
well here is my DP lope idol if anyone is interested, and my SMF rattle... but the lope is interesting, but not drivable, instantly revs to 2200rpm and holds for a second or 2, scary to drive LOL
YouTube - Dp lope idol 95 f250 obs 7.3
my second thing is, i did a sweet burnout for the boys the other night and after that my ABS light has coincidentally been on since then, no leaks, no change in the brakes besides it killed my Cruise controle what the heck! any ideas where to start?
Okay, let's look at the obvious. You did a "sweet" burnout for your friends. First and foremoest.........sweet, I love a good burnout. Second, you need to check the other ABS sensor that is on the truck. It's on the rear axle. And what does it sit on top of? Gears. What happens to gears sometimes during "sweet" burnouts? Yep, they break sometimes. I would pull that sensor and see what you can see. Make sure it's clean, then jack the rearend up and spin the tires so you can inspect the tone ring through the sensor hole. If it's not damaged or something stuck in it, then you are looking for another problem. But that's where I would start for sure.
cody it wasnt a rear gear buster but it was a smaller... donut lol ill check that sensor thoe. no weird noises and my speedo is spot on thoe, gps certified!
and before summer is officially done, im going to a sick burnout and get a video of it for you guys, might as well get the last one out before i stop beating on my poor tires lol its been breaking loose on dry pavment in 3d lately LOL
