Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 09-13-2010, 01:54 PM
DK Farms DK Farms is offline
Garage is empty, add now
DK Farms is starting off with a positive reputation.
Rear gate won't close sometimes
I have an 08 EXPY Eddie Bauer that occassionally when I press the auto-close button on the remote or in the rear compartment, the gate will close but then opens again as if there is an obstacle in the door. Other times it works just fine. Is there a TSB on this or is there some adjustment I can make to make the door close more reliably?
Thanks
  #2 (permalink)
Old 09-16-2010, 02:25 PM
berry1234's Avatar
berry1234 berry1234 is online now
berry1234 is gaining momentum as a positive member of FTE.
There is a tsb. Search for it because I posted it a while back.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 10-26-2010, 11:12 PM
freerider freerider is offline
freerider is starting off with a positive reputation.
I should have looked on this site before taking mine to the dealer... $130 to diagnose and fix...
  #4 (permalink)
Old 12-12-2010, 02:27 PM
Mr.Fr33z3 Mr.Fr33z3 is offline
Mr.Fr33z3 is starting off with a positive reputation.
My wife had a similar issue occur while she was driving, the door opened on its own,
shortly after that it would not open at all.
I found the plug, inside the vented panel on the drivers side, was loose. I squeezed it back together and used a cable tie to secure it and haven't had any additional issues.
  #5 (permalink)
Old 01-14-2011, 04:06 PM
Blacknav Blacknav is offline
Blacknav is starting off with a positive reputation.
Anyone one have details or a full copy of the TSB?
After searching through countless threads I found Berry's list of TSB's and looks like it is: 08-14-5 07/21/2008 Body - Power Liftgate Inoperative/DTC B117B
Does anyone know the details of the TSB (fulltext) or how to fix it. My rear gate stopped working and Its a PITA trying to get all the kids stuff in and out through the hatch glass
Edit: I think I found it. Posting it up in case any one else ever needs it.
http://www.justanswer.com/ford-linco...igator-10.html
  #6 (permalink)
Old 01-22-2011, 11:07 AM
So I pulled the panel off the other day to figure out why my lift gate wouldn't open with the remote or the exterior handle.
I started checking continuity on the wires and found that one of the main connectors going to the latch had corrosion buildup which was preventing the pins from making contact.
I cleaned the connector out with contact cleaner and she is back to normal.
Thanks !!
  #7 (permalink)
Old 02-10-2011, 06:59 AM
BecaExpeditionEL BecaExpeditionEL is offline
BecaExpeditionEL is starting off with a positive reputation.
Thanks !!
Thanks for the information as of this morning my power liftgate will not open electronically or manually.
Is the wire you are referring to inside the panel? I found a few different wires and various connection points.
  #8 (permalink)
Old 02-10-2011, 04:33 PM
If you trace back from the latch handle it goes to a small connector (2 wires i believe) and from there it goes to a larger connector (about 6-8 wires) it was the larger one that had the buildup on my truck. With the panel off it was pretty much in the middle of the lift gate, maybe a bit closer to the pass. side but I would check them all while you have the panel off.
Tags
2007, automatic, button, close, expedition, expendition, ford, gate, hatch, lift, liftgate, lincoln, lock, navigator, open, rear, truck, way, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
