$750 87 F250 4x4 project - Ford Truck Enthusiasts Forums
Old 09-13-2010, 02:17 PM
kelly1mm's Avatar
kelly1mm kelly1mm is offline
kelly1mm is starting off with a positive reputation.
This thread will track the progress of my 1987 F250 4x4 project. I just got this truck on 9/10/10 for $750. It has a 4-speed manual gearbox, manual locking hubs, a 3.55 rear end and a longbed. Got it with 95k miles and it used to be a farm truck. 2k on new tires (uniroyal laredo AWT's 235/85/16 (31.7 inches) on stock rims). To get it home about 15 miles all I had to do was put in new gas. The end result will hopefully be a reliable truck for hauling things to the dump, home depot runs, and light towing. I am not going to be building this truck up into a show truck or a mud bogger - just a "regular" truck. I am new to Ford trucks but can turn a wrench so most/all of the work will be done by me.
Problem areas:
1) rust - see pictures and the cab floor is pretty bad. Cab corners too.
2) Cap - needs to come off and will very soon.
3) front tank seems to not be working (no fuel pump noise when front tank selected and fuel gage pegs to over full - probably sending unit I believe)
4) spark plugs in cylinders 2 and 5 are stuck in the head. I can turn them both so I am soaking in PB blaster and working on them. Hopefully this will work without snaping them off!
5) distributor cap screw (one closest to the engine) will not turn. PB blaster on that as well.
What I have done so far -
1) changed oil and filter
2) new air filter
3) new wires
4) new plugs (motorcraft), still working on 2 and 5!
5) cleaned the truck up. Since it was a farm truck it has a lot of built in grime. I took a lot off but the truck still looks dirty. Here are some pictures of the progress so far. First set is as I got it.
Old 09-13-2010, 02:20 PM
kelly1mm's Avatar
I know it does not look it but here is the truck after being washed and the engine bay cleaned up a bit.
Old 09-13-2010, 02:24 PM
kelly1mm's Avatar
here are some of the interior - pretty basic. Oh yeah - that blue color on the doors and engine bay is the original color.
Old 09-13-2010, 02:25 PM
kelly1mm's Avatar
more interior shots
Old 09-13-2010, 02:32 PM
kelly1mm's Avatar
Rear of truck - newish hitch, tires and wheels, shocks may need some work you think?
Old 09-13-2010, 02:54 PM
jplinville's Avatar
jplinville jplinville is offline
jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.jplinville has a very good reputation on FTE.
Not bad, great price.
You should be able to score interior parts out of an XLT for cheap, or go for Bronco bucket seats.
I see you're having issues with removing a few plugs? Hit it with PB blaster, and try removing them with the engine still warm...it should loosen up for you.
Old 09-13-2010, 04:04 PM
danger-ranger93's Avatar
danger-ranger93 danger-ranger93 is offline
danger-ranger93 is starting off with a positive reputation.
looks pretty good, id say you need to have the front springs re-arched and throw some new shocks on her, noticed the spring was sitting on the bump stop..
Old 09-13-2010, 04:22 PM
court1100f court1100f is offline
court1100f is gaining momentum as a positive member of FTE.court1100f is gaining momentum as a positive member of FTE.
That is a nice truck for the money I picked up a 1990 for $300 and I've got my work cut out for me lol No 4wd to get back into shape though. Thats a damn nice interior it's got looks just like the interior on my 87 F150 what was the original color just solid blue or two tone??? Curiousity lol. my interior was trashed by field mice and god knows what else though. good Score and those 300s are damn near indestructable btw, that is IF you didn't already know that
Old 09-13-2010, 04:49 PM
Blue Rebel's Avatar
Blue Rebel Blue Rebel is offline
Blue Rebel has a good reputation on FTE.Blue Rebel has a good reputation on FTE.
For 750 bucks you got a steal! Maybe its just the pics, but that body looks to be in great shape. Dunno how much bondo might be under that paint job, but youll find out. And that may also be why it doesnt seem to be cleaning up. Is there any clearcoat over that white? There doesnt look to be from the pics.
If your interested, this is what my $300 89 F250 looked like 2 days after I brought it home, the same color your truck was before it was repainted:
Old 09-13-2010, 06:02 PM
kelly1mm's Avatar
The spark plugs are getting shot with PB Blaster twice a day and the vehicle is being driven. I am a chicken when it comes to getting the plugs out - really don't want to break them off so I am just moving them back and forth till I hit major resistance.
Thanks for pointing out the front springs issue - didn't even notice that. I will add that to the list.
Blue Rebel - I like your truck! I am thinking on getting running lights like those down the road. The paint on mine does not seem to have a clear coat and is not professionally done. I am thinking of painting this myself after the rust is cut out / stopped and may go with something close to original with the blue but make it two tone with white as well.
Old 09-13-2010, 06:37 PM
like this???
Lol Obviously I'm Biased but It'd look damn good if done right!!!!
Old 09-13-2010, 07:24 PM
kelly1mm's Avatar
Yep! or vice-versa with white on top and bottom, blue in the middle. My reasons for these colors are that with the blue, I don't feel so bad about the un-repainted parts (since they are blue) and the white is an easy color to make look OK when doing a home paint job. I hope I can get a pass from the 'paint wars' that have gone on in other threads as this truck was $750! Professional paint would be at least $3k around here.
One more thing I noticed when working on the truck is that it is SO BIG! I work on little italian cars all the time (alfa romeo mostly) and it is sometimes cramped in the engine bay. With the truck, I need a step ladder just to get at about 1/2 of the engine and I am 5'11". Also, while washing it, it just kept going and going! What I am trying to say it there is a whole lot of truck in these trucks!
Quote:
Originally Posted by court1100f View Post
like this???
Old 09-13-2010, 07:38 PM
kelly1mm's Avatar
BR,
Are those trucks in the picture you posted a stock f150 and a stock f250? I know the bodies are the same but the f-250 looks so much bigger! That is why I actually bought my truck - I liked the stance. Was looking for a 87-91 4x4 with extra cab for the 5-speed. Was looking for an I6 300 as I read good things here about them so I thought I would be getting a F150. Even looked at a couple but decent (I mean running, not non-rusty) were 1200-2500. This came up and was cheap so I went to take a look and, again, really liked the stance. Thought about it for a couple of days (originally wanted the extended cab and a 5 speed) and pulled the trigger. So far I am happy as I think any truck that runs, turns, stops, and can do all three for a 15 mile trip home has to be worth $750.
One more thing - no inspections or emissions for historic vehicles (20yrs) here in MD! $51.50 for 2years of tags too! Took all of 20 minutes to get the truck on the road and legal!
Old 09-13-2010, 08:25 PM
White 97 xlt's Avatar
White 97 xlt White 97 xlt is offline
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Quote:
I know what you mean about BIG.. Mine is Ext cab long bed, As Justin Wilson would say "I garonteee" you a wash and wax is an ALL day job, maybe a day and a half in winter months. (shorter days)
Old 09-13-2010, 09:52 PM
Blue Rebel's Avatar
lol yup, in that pic both trucks are bone stock, all the way down to tire size. I agree, Ive always loved the stance of the 3/4 ton trucks. Although I gotta say, that half ton had a real nice stance to it when I first got it...
Spark Plugs change V10 for dummies w/pictures. sammie0126 Excursion - King of SUVs 36 05-04-2015 11:36 PM
My new F250 questions and plans Jayy 1987 - 1996 F150 & Larger F-Series Trucks 6 04-06-2015 02:39 PM
Repalce 5 of 6 Motor Mounts Macs1964F100 1961 - 1966 F-100 & Larger F-Series Trucks 14 03-24-2014 05:08 PM
Broken Idle Mix Screw J.McConnell 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-11-2014 08:02 PM
Changed spark plugs 5.4 3V @ 52k miles - pics D-Rock 2007 - 2014 Expedition & Navigator 11 07-26-2011 12:28 PM
Tags
1995, 250, 4x4, 87, 91, engines, f150, f250, f250s, ford, lifted, oil, rebel, them, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
