03-04 towing mirrors
I don't believe the turn signals were an option on the earlier years. They will mount to the truck just fine. I saw a thread somewhere, where the person bought the newer mirrors, and spliced the mirror wires into the wires for the turn signals somewhere under the dash, if I remember correctly. You can do it if you really want to, but you won't be able to use the wiring harness.
I just replaced my dinky mirrors with the towing ones, thought about going with a newer year but as stated the wiring harness is different '99 are round and I think '05+ are square. I ended up ordering the ones for the 99 (round plug) from truck champ, they are pretty good quality, telescopic and correct harness. plus if you do a search for truck champ and coupon you should be able to fine a 10% off one that will work or I think i remeber seening a coupon code in last month diesel power mag.
from their website
:Towing Mirror BestInAuto Safe View Power 202506 Black DRIVER & PASSENGER Side
<DL class=ProductDetailsGrid><DT style="DISPLAY: none">RRP: </DT><DD style="DISPLAY: none"><STRIKE>$163.99</STRIKE> </DD><DT>Price: </DT><DD>$163.99
<NOSCRIPT></NOSCRIPT></DD><DT> </DT><DD><INPUT onclick="return chksubmit()" type=image alt="" src="http://www.truckchamp.com/templates/TruckChampFixed/images/blue/AddCartButton.gif"> </DD><DT class=ProductSKU>SKU: </DT><DD class=ProductSKU>202506 </DD></DL>
from their website
Yeah, somewhere in 02 they started wiring them and the 03's were the first to offer the lit mirrors (I think).
I scored a set for my 02 and was able to plug them in - only powering the mirror functions though. I had to hard wire the other functions (running lights, directionals, and heat). While I was at it, I wired the heat to a switch instead of just making it 'key-on hot' like the factory.
There are LOTS of threads on the subject - just start searching for 03 mirror upgrade.
littlejohniii
08-15-2008 01:46 PM
