95 460 gas distributor install ?
Old 09-12-2010, 10:29 AM
bigdawg13's Avatar
bigdawg13
bigdawg13 is offline
Shop manual on line states that timing is not adjustable, are the notches on the dist, and the block supposed to line up and forget about it?
Old 09-12-2010, 06:10 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,164 Likes on 919 Posts
The timing is adjustable. Ryan has a great writeup here: Ford Fuel Injection Setting the timing
Check with a real service manual to verify what the base timing should be set to on your 7.5L engine.
alchemist1
09-28-2012 06:48 AM
joe f350
46
04-20-2009 11:46 AM
LIGOOMBA
11-10-2008 08:39 PM
rocktestr
02-11-2002 11:06 AM
cbwarrior
11-08-2001 07:00 PM
Quick Reply: 95 460 gas distributor install ?
