1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Power Point is dead
Old 09-12-2010, 05:44 PM
pedz's Avatar
pedz
pedz is offline
4wd Low
Power Point is dead
2000 Ford F-250 Diesel Lariat...
My power point access died quite a while back. This weekend, while goofing with the GPS, I looked into it. Its not a bad fuse. It seems terribly hard to get into it and even when I do, I'm not sure what I'd be looking for.
Has anyone else had this problem?
Thank you,
Perry
Old 09-12-2010, 07:31 PM
senix's Avatar
senix
senix is online now
Received 1,415 Likes on 1,010 Posts
so you checked your cigarette lighter fuse?
Old 09-12-2010, 07:44 PM
pedz's Avatar
pedz
pedz is offline
4wd Low
The cigarette lighter works.
Old 09-12-2010, 07:52 PM
senix's Avatar
senix
senix is online now
well, it was an idea. I have no idea on how to get it out. For mine the little panel that the power point and the 4x4 switch pop out exposing bolts that hold the center stack on.
That will just pop off exposing the stereo and stuff.
Not sure of your year.
Old 09-12-2010, 08:39 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
The power point and the cigarette lighter are on separate fuses, just in case you didn't know that.
Old 09-12-2010, 08:48 PM
pedz's Avatar
pedz
pedz is offline
4wd Low
Yes. It seems the power point fuse is inside the engine compartment -- Fuse 10 as I recall. At least, that's what my books says.
senix's Avatar
senix
senix is online now
Nope, learn something new everyday!
Old 10-10-2010, 05:32 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
Thank you,
Perry
pedz --
Did you ever get this resolved?
I am having a similar issue, but mine is with the cigar lighter port. I tried to remove it today...after pulling the blown 20A fuse #12; but no go.
Anybody know how to remove the cigar lighter???
I tried by removing the trash holder hook piece...and getting access to the rear of cigar lighter port. But...could not remove it...
Any help would be appreciated!
biz
Old 10-11-2010, 02:09 PM
SteveH-CO's Avatar
SteveH-CO
SteveH-CO is offline
My power point fuse blew and I replaced it. I then plugged an accessory into the outlet and as I plugged it in, the fuse blew again. Some power point sockets appear to short internally from other posting I have seen. I haven't debugged mine any further, butwill, someday.
Old 10-11-2010, 02:13 PM
ChargersFanInCO's Avatar
ChargersFanInCO
ChargersFanInCO is offline
Yes, they most certainly do....I skipped over that little step one time and over-analyzed the circuit for around 3 hours before figuring it out. Glad you didn't waste much time...hopefully
Old 10-13-2010, 10:49 PM
biz4two's Avatar
biz4two
biz4two is offline
Arrow
What I am curious about is how to remove the cigar socket???
I took the trash hook panel off...and was able to get at the back of the socket, but was unsure how to remove the socket. So...rather than breaking something...I installed the trash hook back.
Anyone know how to remove it?
biz
perryg114
01-31-2015 12:07 AM
perryg114
05-23-2014 03:07 PM
cobra427
01-10-2008 08:49 AM
blaircole
Ontario Chapter
08-31-2005 07:01 PM
Quick Reply: Power Point is dead
