400M & 460 Flywheels - Ford Truck Enthusiasts Forums
Old 09-12-2010, 04:43 PM
Hazmat 67 Hazmat 67 is offline
Hazmat 67 is starting off with a positive reputation.
Question 400M & 460 Flywheels
I will be converting my 73 4x2 Crew to 4-wheel drive this fall. I plan on running a rebuilt 400M mated to a ZF 5-speed tansmission bolt to a NP 205 transfer case so I have overdrive for freeway driving when traveling in the future. I have a 460 flywheel,pressure plate and disc that were included when i bought the transmission. I know that there is a difference with the clutch discs as to the 460 has a larger 10 slpine center hub 12" diameter and the 400M has a smaller 10 spline center hub 11" diameter. I know that I can fab the mechanical clutch linkage to the 400 with little issues. I need to know if it is at all possible to bolt up the 460 flywheel as it has the larger 12" clutch assembly instead of the 11" that was bolted up to the 400M flywheel. The 460 flywheel had casting # RF-D9TE-6380-BB with a cast oval with a 253P in the center also on the flywheel surface. It has some stamped letters that read E7TR-AA D on a flat machined area near the outside edge. The diameter is 15 7/16 +/_" with a 180 tooth count for the starter ring. I realize there may be an issue with the balance of the 2 different flywheels and that is my main concern prior to bolting in the complete assemble during the conversion. I am open to any other issues that may pop-up if you have do this swap before. Thanks in advance on any information.
Hazmatt 67
4x2 Crew (4x4 Soon)
Old 09-12-2010, 06:28 PM
fordtrucknut's Avatar
fordtrucknut fordtrucknut is offline
fordtrucknut is starting off with a positive reputation.
Both engines have different balances...and If i'm not mistaken...different bolt patterns as well...Autozone carries a Diaphragm style clutch that is 12 inch (According to the parts guy..but I would verify) PN# NU0080 that will fit on a 351M/400 Flywheel
Old 09-12-2010, 11:19 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
If you have an 11" clutch you have a 351M flywheel, not a 400 flywheel.
And...if you have a 11" clutch, the engine may not be a 400, it could be a 351M.
D7TZ6375E .. 351M Flywheel-Use with 11" clutch.
Fits: 1977/79 F100/350 / 1978/82 Bronco / 1980/82 F150/350 & Econoline.
D7TZ6375D .. 400 Flywheel-Use with 12" clutch.
E7TR-AA = E7TZ6375A .. 460 Flywheel-Use with EFI.
Fits: 1987/96 F250/350, F(Super Duty) & E250/350.
E7TZ6384A .. Flywheel Ring Gear-180 teeth.
Fits: 1977/82 351M/400 / 1983/96 460.
Ford did not offer the 460 with a manual transmission or with 4WD until 1983.
btw: There is no such thing as a 400M / It's just plain 'ol 400.
Old 09-13-2010, 09:57 PM
400 & 460 Flywheels
Thanks guys for the information regarding this issue. I will check to verify if the engine is a 351M and not a 400 as stated due to the smaller flywheel prior to rebuilding this engine.
Hazmat 67
73 4x2 Crew ( 4x4 Soon)
Ford 460 engine needing a good old 12" clutch bell housing. ezsqueez 1973 - 1979 F-100 & Larger F-Series Trucks 0 12-04-2015 06:04 PM
460 swap & flywheel tooth count. Red Mercury Engine Swaps 8 09-01-2015 10:13 PM
TMeyer ZF5 Adaptor For 335 Series Engines Gary Lewis 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 36 08-04-2015 04:21 AM
Solid flywheel conversion in the future FordOwnerJoey Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 10-05-2013 07:34 PM
Bellhousing, clutch for a 460 and t-18 tranny bigdan1979f-250 Clutch, Transmission, Differential, Axle & Transfer Case 2 09-26-2009 08:58 PM
Tags
1979, 1986, 400, 400m, 460, big, block, carburetor, count, f100, fits, flywheel, ford, tooth, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
