1956 F350 to accept later 8 lug wheels on the front end,is it possible? - Page 2 - Ford Truck Enthusiasts Forums
Old 07-20-2014, 05:00 PM
Olweldinrig's Avatar
Olweldinrig Olweldinrig is offline
Olweldinrig is gaining momentum as a positive member of FTE.Olweldinrig is gaining momentum as a positive member of FTE.
Just some info...
Old 07-20-2014, 06:30 PM
GB SISSON's Avatar
GB SISSON GB SISSON is online now
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
I have lots of pictures of the adapters etc, but they are on my old computer. I keep thinking someone can load them onto the new one, but I can't. I think if you go to wheeladapters.com you will find the 8 lug to 8 lug dually adapters. They are a high quality adapter. Unfortunately, the price reflects this.....
Old 07-20-2014, 09:15 PM
havi's Avatar
havi havi is offline
I'll have the Roast Duck
havi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to allhavi is a name known to all
thanks so far. I see the U-bolt spacing is 2" wide for the 1 ton, and 1.75" for the 1/2 and 3/4 ton.
In this chart, it shows more differences between the 1/2 and 3/4 ton vs the 1 ton.
Old 07-20-2014, 10:16 PM
Jules The Great Jules The Great is offline
Jules The Great is gaining momentum as a positive member of FTE.Jules The Great is gaining momentum as a positive member of FTE.
I would think you could also take the 6 bolt hubs to a machine shop and have the hub centering part of the wheel machined to the right diameter for the 8 bolt and have a new bolt pattern drilled. If you had some machine tools you should be able to do this yourself as well.
54 ford f-350 powertrain & suspension parts for sale 54fordf350 Ford Truck Parts for Sale 10 11-03-2016 08:45 AM
1953 - 1956 Ford Truck F350 Medium Duty Front Clip Johnnynobody 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 07-04-2015 05:57 AM
Speaking Of Front End Swaps... wantahertzdonut 1987 - 1996 F150 & Larger F-Series Trucks 2 08-16-2014 10:50 PM
1956 F250 axle question bmann52 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 05-22-2014 11:55 AM
1955 F350 Front Suspension Options cwmcobra 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 04-16-2010 05:14 AM
Tags
1956, 2000, 8lug, 96, axle, bolt, change, f350, ford, front, hub, lug, roush, spindles, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
