High idle mode , using upfitter switch??
Getting ready to do the high idle thingy. I found in the tech folder, as well as help in the normal threads, but still want to make sure. It says that wire number 322 is the one, light blue with yellow stripe. Connect this wire to wire number 294 which is white with light blue stripe. This wire (294) is hot with the key on. But this way i still need a switch. My question is, can't i just connect one of the upfitter switches to wire number 322 and be done with it. The upfitters also is hot with key on. I guess the info in the tech folder was for folks without the upfitter switches. Just wanna make sure before i do something wrong, thanks. herb
This is the write up I used to do my high idle mod. Very plain and simple directions using the upfitter switches.
Howto: 05-06 High Idle (AIC/SEIC/BCP) - Diesel Forum - TheDieselStop.com
_________________________
Vic
2006 F250 6.0, CC, Lariat, High Idle mod, Dieselsite coolant filter, ScanGauge II w/BlendMount
Vic
Trash Hauler
6.7L Power Stroke Diesel
03-03-2015 06:44 PM
electric_jimmer
05-28-2012 05:31 PM
