Help! Wont start, wont crank? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-11-2010, 02:33 PM
mrbleth mrbleth is offline
mrbleth is starting off with a positive reputation.
Exclamation Help! Wont start, wont crank?
Anybody have any advice? I got a 2002 Ford F250 Diesel 7.3 Automatic. I drove to store, parked, turned it off. Returned 5 min later, tried to start it. Nothing?! Wont crank..nothing. Batteries are good, lights on dash are fine. I think it's an ignition thing? I checked all fuses under the dash, all good. Please reply with any similar experiences/advice, etc. Thanks!
Old 09-11-2010, 07:44 PM
sandmanf250 sandmanf250 is offline
sandmanf250 is gaining momentum as a positive member of FTE.
wont start
crank position sensor.and a 10 mil. box wrench.
Old 09-11-2010, 07:47 PM
JT301's Avatar
JT301 JT301 is offline
JT301 is starting off with a positive reputation.
Does the motor turn over and won't start, or does it not turn over at all?
Old 09-11-2010, 09:09 PM
to jt301: it doesnt turn over at all, starter doesnt click, nothing. batteries good, fuses good, lights on dash good, wont start in park or drive. seems like the electricity isnt getting to starter? very strange because truck was driving fine 5 minutes before. I had it towed to my ford dealership.
Old 09-11-2010, 09:47 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
Quote:
It's not supposed to start in drive, only Park or Neutral. That's your most likely suspect if nothing at all happens when you turn the key.
If you hold the key to start for 10 seconds, do the dash lights dim at all? Are any of the battery cables warm after doing that?
Welcome to FTE.
Old 09-11-2010, 09:52 PM
docsuby docsuby is offline
docsuby is starting off with a positive reputation.
Next check your grounding cable, even re-ground it with a set of jumpers if you have to.
Old 09-11-2010, 10:31 PM
I had the Camshaft Position Sensor replaced like 3 months ago, is that the same as the crank position sensor?
Thanks for the welcome, this is a great forum with lots of good advice and friendly people. Sorry, my goof, I meant to say it wouldn't start in Park and Neutral..Not Park and Drive.
The dash lights dont dim or anything, seems to have plenty of juice. Battery cables dont get warm.
Old 09-12-2010, 08:40 AM
Lou Braun Lou Braun is offline
Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.Lou Braun has a good reputation on FTE.
I just went through this type of problem with an '06 diesel. There is a bit of electrical troubleshooting needed to pinpoint the problem.
From your description, there is no click when you turn the key and the engine does not crank. Try this with a door open and see if your interior lights dim at all when you turn the key to start. Any dimming and the battery cables/connections would be the problem.
If it is a no click, no crank condition, any one of the following can be the cause.
(1) Fuses - check your owners manual for the fuse leading to the starter relay and to the PCM. Either fuse will cause this problem.
(2) Starter relay - you would need to pull the starter relay (your relay is probably in the junction box in under the steering wheel) and see if voltage gets to the relay when you turn the key to the start position. If you have voltage to the relay then you know the ingnition switch and the transmission range sensors are OK. The relay itself can be checked with an ohm-meter, but they are cheap enough to just replace.
(3) Ignition switch - check for voltage at the starter relay. If no voltage, pull the fuse leading to the relay and check for voltage on the input side of the fuse. If no voltage, disconnect the connector leading from the ingition switch and check there. (You will need to get the electrical manual for your exact model year truck to get the right connector and wire color ID).
(4) Starter solenoid/starter - check for voltage at the starter solenoid positive terminal (between the terminal and ground) when the key is turned to start. (Need two people for this one since the solenoid is on the starter). If there is voltage at the solenoid, then the starter/starter solenoid is the problem and a new starter is needed. If no voltage then voltage is not getting to the starter and the problem is in one of the above steps. You can run a jumper cable from battery positive to the starter S terminal to verify the engine cranks (take care with this step). If the engine cranks then the starter is OK. If the ingnition key is in the on position, the engine will start when jumped.
(5) PCM - This involves taking a resistance reading between the ground side of the starter relay and ground. (The PCM provides the ground side of the starter realy). If the resistance is high, the PCM could be bad.
There are other checks that a professional would do, but this should get you started.
Lou Braun
Truck cranks but will not start. TheNamesTopher 1999 - 2003 7.3L Power Stroke Diesel 7 01-05-2016 03:33 PM
Won't start. 90'F150 1987 - 1996 F150 & Larger F-Series Trucks 18 08-19-2013 03:06 PM
starting problems cjtim 1997 - 2003 F150 12 12-23-2011 07:24 PM
Ford '02 F250 won't start... RonHouston 1999 to 2016 Super Duty 2 06-19-2011 07:33 AM
1999 F150 Cranks but wont start ispankyi 1997 - 2003 F150 3 11-22-2009 08:35 PM
Tags
1999, 2006, 73, batteries, crank, diesel, duty, f250, f450, ford, good, make, solenoid, super, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
