6.4 block heater cord routing and location lots of pics
I deceided to put a cord on my truck, I routed the cord and connected it to the block heater, problem is how it he world do you tighten the nut to secure the cord to the block heater? I did get a couple of threads with my fingers but there is just no room for a wrench, or even a mexican socket set.
Even thought I live in Texas, we will be traveling to Kansas City for a week or so in the Kansas City area. Used to live there, in 2008, just before Christmas, it was a high of 15 below zero, not windchill, actual temp, so it can be dastardly there. So for a little insurance, I thought it might make it a little easier on the engine, and for a $20 investment.
Thanks for the write-up Scott!
My chord came with a smashed up plug - so much so that the cap doesn't fit anymore and the pins are loose. Not sure how it happened, but I brought it to the dealers attention a couple weeks after I got the truck once I found it and they told me they would not replace the chord and that it was "a major repair since it is connected to the engine block". Liars.. Anyway, good to know its pretty easy to do.
Sounds like they need to go to school then. Sad, a simple cord.
Cord
Senix, thanks for the pics. They will come in handy real soon.
I just bought a Zero Start 3600008 cord for $18.00 at Tommy's Truck Parts in Waldorf, MD. Ford wanted $75.00 for it. The only difference I've heard is the Ford version comes with the wire loom.
Now I have to buy some wire loom and wire ties. Does anyone know if there are any heat resistant wire ties made and where they can be bought?
The install does not look like fun.
Thanks...
Neil
Thanks...
Neil
If you looked on the passenger side, inside the front bumper and didn't see a cord there then you will need to order.
Hey I am new to the Forum but have been reading it for years. Thank you for such great info. I recently bought a 2008 F350 King Ranch. I have found the plug that is just inside the bumper next to the front tow hooks. If I plug it into the house or to a Timer is that all that I need? Again pretty new and not sure that I would ever really have to use it just would like to know just in case I do need it. Thank you
Travis
Travis
That is all you need to do, just plug it in.
Don't forget it though when you get ready to leave in the morning.
pics
yea so far I cannot make heads or tails of the pics in this right up. I cannot find my plug or evidence of its location without crawling aroung under the truck. why couldnt this be easier? anyhow was wondering if someone could post some pics with more depth and maybe some arrows or something??? ya know for dummies!lol thanks in advance!!!! COLD ON THE WAY~
If not then you need the cord.
I installed mine today in 18 minutes at night without a lift in my driveway. Only tool was a long screwdriver. I started by sliding head first on my back under the passenger side door just behind the front wheel. Found the frame and used a flashlight placed 3-4 feet towards the rear shining up by the starter. Since it was 80 degrees here today, I still had condensation dripping from my AC condenser off the frame Right by my head. (May help for reference). The starter also has a heavy gauge red cable coming off. Just above the starter (easiest to see by sitting 2 feet behind the front wheel looking up towards the engine inside of the frame rail) is a circular opening with two prongs inside. That's the block heater already installed in the block. To maneuver the cord up there, I slid my right arm up around the frame rail through the wheel well. I was able to get 2-3 fingers far enough to reach the heater coil. My left hand went straight up around the starter to maneuver the cord in place. I then used the screwdriver in my left hand to gently push the plug into place. Once snug, maneuver the nut over the rubber plug and turn using 2 finger in each hand about a 1/4 turn each time.
Can't really explain how I routed the male plug back to the bumper, but just make sure you stay away from any moving parts as well as hot ones.
I hope this helps those who are getting ready to do this.
#30
Nut. I could only turn it a small amount then flip the
Channelocks over for a little more turn. Then repeat.
