6.4 block heater cord routing and location lots of pics - Page 2 - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 10-30-2010, 08:44 PM
Gearitis Gearitis is offline
Gearitis is gaining momentum as a positive member of FTE.Gearitis is gaining momentum as a positive member of FTE.
I deceided to put a cord on my truck, I routed the cord and connected it to the block heater, problem is how it he world do you tighten the nut to secure the cord to the block heater? I did get a couple of threads with my fingers but there is just no room for a wrench, or even a mexican socket set.
Even thought I live in Texas, we will be traveling to Kansas City for a week or so in the Kansas City area. Used to live there, in 2008, just before Christmas, it was a high of 15 below zero, not windchill, actual temp, so it can be dastardly there. So for a little insurance, I thought it might make it a little easier on the engine, and for a $20 investment.
Old 10-31-2010, 01:03 PM
KC8QVO's Avatar
KC8QVO KC8QVO is offline
KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.KC8QVO has a great reputation on FTE.
Thanks for the write-up Scott!
My chord came with a smashed up plug - so much so that the cap doesn't fit anymore and the pins are loose. Not sure how it happened, but I brought it to the dealers attention a couple weeks after I got the truck once I found it and they told me they would not replace the chord and that it was "a major repair since it is connected to the engine block". Liars.. Anyway, good to know its pretty easy to do.
Old 10-31-2010, 02:34 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Sounds like they need to go to school then. Sad, a simple cord.
Old 10-31-2010, 06:00 PM
Neil64 Neil64 is offline
Neil64 is starting off with a positive reputation.
Cord
Senix, thanks for the pics. They will come in handy real soon.
I just bought a Zero Start 3600008 cord for $18.00 at Tommy's Truck Parts in Waldorf, MD. Ford wanted $75.00 for it. The only difference I've heard is the Ford version comes with the wire loom.
Now I have to buy some wire loom and wire ties. Does anyone know if there are any heat resistant wire ties made and where they can be bought?
The install does not look like fun.
Thanks...
Neil
Old 10-31-2010, 06:11 PM
senix's Avatar
don't know if there are any AF wire ties or not.
I is a bear to route that cord correctly.
Old 11-08-2010, 11:51 AM
Glockem45's Avatar
Glockem45 Glockem45 is offline
Glockem45 is starting off with a positive reputation.
Thumbs up
Scott,
I took some time this weekend to search to see if I have the cord or not on my F250, but I just can't seem to find anything. I guess I need to order the cord from Ed now, and let you install it for me.
Old 11-08-2010, 12:49 PM
senix's Avatar
Quote:
Originally Posted by Glockem45 View Post
Scott,
Sure..why not
If you looked on the passenger side, inside the front bumper and didn't see a cord there then you will need to order.
Old 11-17-2010, 03:29 PM
FSTBLL42 FSTBLL42 is offline
FSTBLL42 is starting off with a positive reputation.
Hey I am new to the Forum but have been reading it for years. Thank you for such great info. I recently bought a 2008 F350 King Ranch. I have found the plug that is just inside the bumper next to the front tow hooks. If I plug it into the house or to a Timer is that all that I need? Again pretty new and not sure that I would ever really have to use it just would like to know just in case I do need it. Thank you
Travis
Old 11-17-2010, 03:37 PM
senix's Avatar
Quote:
Travis
That is all you need to do, just plug it in.
Don't forget it though when you get ready to leave in the morning.
Old 11-21-2011, 09:49 PM
rblaine9000's Avatar
rblaine9000 rblaine9000 is offline
rblaine9000 is starting off with a positive reputation.
pics
yea so far I cannot make heads or tails of the pics in this right up. I cannot find my plug or evidence of its location without crawling aroung under the truck. why couldnt this be easier? anyhow was wondering if someone could post some pics with more depth and maybe some arrows or something??? ya know for dummies!lol thanks in advance!!!! COLD ON THE WAY~
Old 11-21-2011, 09:57 PM
senix's Avatar
Quote:
Start by looking at the inside of the front bumper on the passenger side. Just down by the headlight area or tow hook area. Is there a cord there with a standard plug for a 110V outlet?
If not then you need the cord.
Old 11-21-2011, 10:39 PM
RM2738's Avatar
RM2738 RM2738 is offline
RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.RM2738 has a very good reputation on FTE.
I installed mine today in 18 minutes at night without a lift in my driveway. Only tool was a long screwdriver. I started by sliding head first on my back under the passenger side door just behind the front wheel. Found the frame and used a flashlight placed 3-4 feet towards the rear shining up by the starter. Since it was 80 degrees here today, I still had condensation dripping from my AC condenser off the frame Right by my head. (May help for reference). The starter also has a heavy gauge red cable coming off. Just above the starter (easiest to see by sitting 2 feet behind the front wheel looking up towards the engine inside of the frame rail) is a circular opening with two prongs inside. That's the block heater already installed in the block. To maneuver the cord up there, I slid my right arm up around the frame rail through the wheel well. I was able to get 2-3 fingers far enough to reach the heater coil. My left hand went straight up around the starter to maneuver the cord in place. I then used the screwdriver in my left hand to gently push the plug into place. Once snug, maneuver the nut over the rubber plug and turn using 2 finger in each hand about a 1/4 turn each time.
Can't really explain how I routed the male plug back to the bumper, but just make sure you stay away from any moving parts as well as hot ones.
I hope this helps those who are getting ready to do this.
  #28
Old 11-22-2011, 06:56 AM
Much more info. Thanks guys!
  #29
Old 11-23-2011, 10:34 PM
Ian123's Avatar
Ian123 Ian123 is offline
Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.Ian123 has a very good reputation on FTE.
Thanks for the pics, I've been looking for that dang thing forever. I kept looking for a 2 or 3 prong plug, I didn't know there was a cover on it.
  #30
Old 12-04-2011, 09:31 AM
BROWN DOG KTM's Avatar
BROWN DOG KTM BROWN DOG KTM is offline
BROWN DOG KTM is gaining momentum as a positive member of FTE.BROWN DOG KTM is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by Gearitis View Post
I deceided to put a cord on my truck, I routed the cord and connected it to the block heater, problem is how it he world do you tighten the nut to secure the cord to the block heater? ...
I used a 4 1/2" pair of Channelocks on the front side of the
Nut. I could only turn it a small amount then flip the
Channelocks over for a little more turn. Then repeat.
Block heater tips Tugly 1999 - 2003 7.3L Power Stroke Diesel 70 01-06-2016 10:13 PM
Don't assume your block heater works! / How to test your block heater FarmingF250 1999 - 2003 7.3L Power Stroke Diesel 11 01-04-2016 08:29 PM
Zerostart 350-0069 Engine Block Heater install. strokin83 6.7L Power Stroke Diesel 10 02-06-2014 01:15 PM
engine block heater indicator light? Pro DIY 1999 - 2003 7.3L Power Stroke Diesel 6 01-22-2014 05:44 PM
Prayers for partsguyed(update 1/13/11) (another update) (Update This just in) Deluxe06 1999 to 2016 Super Duty 66 02-15-2011 02:45 AM
Tags
2000, 2010, 350, 64, 64l, block, cord, extreme, f150, ford, heater, international, location, pic, powerstroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
