What kind of gas tank are you using under your bed? - Ford Truck Enthusiasts Forums
Old 09-11-2010, 12:31 AM
51phil's Avatar
51phil 51phil is offline
51phil is starting off with a positive reputation.
I am going to move my gas tank to under my bed on my 51 F1. Which tank is the easiest to install? Any pics?
Old 09-11-2010, 01:05 AM
corner27's Avatar
corner27 corner27 is offline
corner27 is starting off with a positive reputation.
Is there a benefit to moving the tank under the bed?
Old 09-11-2010, 02:22 AM
Julies Cool F1 Julies Cool F1 is offline
Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.Julies Cool F1 has a great reputation on FTE.
Hi Phil
Alot of folks like to move it out there as they feel it's dangerous in a collision to having it in the cab.
There are some Mustang tanks people are putting in out there, and lots of threads on the subject.
But since you don't have 25 posts yet, you can't use the search function. So, I'll see if I can find a couple and post the links here:
Installing a Mid-60's Mustang Gas Tank In A 1953 F-100 .: Articles
http://www.ford-trucks.com/forums/95...nk-in-cab.html
http://www.ford-trucks.com/forums/88...-with-efi.html
http://www.ford-trucks.com/forums/65...questions.html
http://www.ford-trucks.com/forums/61...-question.html
http://www.ford-trucks.com/forums/56...-gas-tank.html
There's tons more - I'll let you start with those!
Have fun!!!
Old 09-11-2010, 05:51 AM
Last Chance 56's Avatar
Last Chance 56 Last Chance 56 is offline
Last Chance 56 is starting off with a positive reputation.
Got with a poly, alum, or a stainless tank. Trust me you will come out cheaper in the end. If you do go with the mustang tank (which is cheaper and easy to do) you better make sure you seal that bad boy up because rust will rear its ugly head, it will.
Old 09-11-2010, 09:24 AM
Old F1's Avatar
Old F1 Old F1 is offline
Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.Old F1 has a good reputation on FTE.
Quote:
Would that rust be internal or external or both? Is this only applicable when the Mustang tank is installed in f1ís or on the original mustangs as well?
Old 09-11-2010, 10:46 AM
epp's Avatar
epp epp is offline
epp is gaining momentum as a positive member of FTE.
had a fuel cell in the bed put now have moved to a tank between the frame. measured the room and ordered on from tanks inc online. good prices imho TANKS Inc. gas tanks for street rods and custom cars and trucks
Old 09-11-2010, 11:10 AM
ZOOT's Avatar
ZOOT ZOOT is offline
ZOOT has a good reputation on FTE.ZOOT has a good reputation on FTE.
Same with me. I got a Tanks inc tank and mounted it between the frame below the bed. I fabbed my own mount for it. You'll need to move the small crossmember from the frame and move it to the end of the frame to make room. The tricky part is figuring where the filler tube will end up. You want it flush to the bed wood or just below it
Old 09-11-2010, 11:42 AM
low54's Avatar
low54 low54 is offline
low54 is starting off with a positive reputation.
I purchased a mustang tank for my '54, it fits right between the rear frame rails...very little fab work in constructing a frame...you can seal the interior with POR-15 sealer...
Old 09-11-2010, 12:24 PM
Randy Jack's Avatar
Randy Jack Randy Jack is offline
Randy Jack has a good reputation on FTE.Randy Jack has a good reputation on FTE.
I used a 25-gallon tank from a 78 Bronco because I didn't want to fill thru the bed floor. My tank fills thru the driver rear fender.
Gallery: 1956 Ford F100 4x2 - Rear Gas Tank
The filler door install:
Gallery: 1956 Ford F100 4x2 - Gas Filler Door
Good luck.
Old 09-11-2010, 03:55 PM
KidShalene's Avatar
KidShalene KidShalene is offline
KidShalene is starting off with a positive reputation.
Ditto on the Tanks Inc. tank, here's mine in mock-up.
Old 09-11-2010, 07:32 PM
Poison Oil Racing's Avatar
Poison Oil Racing Poison Oil Racing is offline
Poison Oil Racing is starting off with a positive reputation.
Good luck.
I just went through your photo album on this project and you did exactly what I am planning on doing because I am putting a '58 bed on the 76 and the bottom of the bed hits the top of the tank.
Thanks for the detailed pictures.
Mark
Old 04-24-2014, 07:45 PM
Sik'scustom56 Sik'scustom56 is offline
Sik'scustom56 is starting off with a positive reputation.
Quote:
What tank did you go with? there are a couple that look like they may work but i dont want to accidentally order the wrong one and have to further delay the build!
Old 02-22-2015, 07:05 PM
Outlaw56 Outlaw56 is offline
Outlaw56 is gaining momentum as a positive member of FTE.Outlaw56 is gaining momentum as a positive member of FTE.
Nice thread for anyone at this stage of the build!
Old 02-22-2015, 09:19 PM
smallello's Avatar
smallello smallello is offline
smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.smallello has a great reputation on FTE.
I looked at a couple of different tanks but I didn't want to move the rear cross-member.
I went with the Mid-Fifty aluminum tank that mounts to the cross-members not the frame. I fits between the frame and cross-members so nothing to move or cut.
I installed a side fill tank with a flip cap on the fender.
Old 02-23-2015, 09:27 AM
Thanks smallello, I just happen to have two of those Mid Fifty tanks on hand. They are for two other half tons, but the one I am currently working on is a one ton dually with smoke stacks and flatbed. I was not going to use the mid fifty tank but after looking at your picture, I might be able to. Im really interested in how you adapted the fill opening to come out somewhere else instead of the of the bed. I actually would like it to come out in the middle rear, but sides could be a option as well. I have tons of room under the flatbed to get the tank higher than it was designed to be, but doing so might compromise the option of easy removal. Can you tell me more about the way you did that, or did you order yours that way from Mid Fifty?
moving fuel tank 1951 F1 mspin54 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 02-04-2017 11:18 AM
WHAT IS MY TANK WORTH HILLBILLY BOB 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 07-23-2015 11:16 PM
Price of a 51 F1 cab? crager5 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 04-14-2015 08:56 AM
IN CAB GAS TANK WVTOMMY 1967 - 1972 F-100 & Larger F-Series Trucks 9 08-08-2011 12:21 PM
Under Bed Gas Tank uc4me 1948 - 1956 F1, F100 & Larger F-Series Trucks 39 08-23-2006 11:08 PM
Tags
1956, bed, f1, fender, filler, ford, fuel, gas, lid, mount, rear, tank, tanks, truck, wood
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
